[AG-TECH] enter venue/venue server on AG2.0 final
Thomas Uram
turam at mcs.anl.gov
Mon Jul 7 14:16:23 CDT 2003
Hi Lewis:
The problem is that the SOAP server is, for some reason, not locating
the service object associated with the URL you are giving for the
venue. So, while it should complain that it can't find the service
object, it wrongly complains about not finding the method.
It sounds like a problem with your cfg or dat file; I know you said it's
not, so it could be elsewhere. If you send your .cfg, .dat, and
VenueServer.log files to me, I'll take a look.
Tom Uram
Lewis Grantham wrote:
>Hi all,
>have followed similar threads here to little avail. This is not an issue with
>cfg or dat files it seems, and after some digging have decided to post this to
>see if theres any undocumented way foward.
>I am runnning w2k/sp4 machines with all the recommended bits from:
>http://www-unix.mcs.anl.gov/fl/research/accessgrid/software/releases/2.0/windows.html(full
>details on request of course - but vanilla flavour Ag2.0final)
>Am also running on UK E-Science certificates and signing policy, if thats in any
>way important. (i.e. Not Ti Leggett supplied ones)
>we have two intended machines in the main - a dedicated display server, and an
>encoder (audio and video production services on one base unit). A third control
>server can perform any roles (node management/sevice etc) as required.
>Everything appears to work fine, we can manage the node, set up all services
>required, and run all service related py scripts in -d mode with no obvious
>issues.
>However, we cannot under any circumstances join our own venue server
>effectively. When we run any VenueClient script ,we get the same error as
>others here have:
> (venueState, self.privateId, streamDescList ) = Client.Handle( URL
>).get_proxy().Enter( self.profile )
>followed by:
>faultType: <Fault SOAP-ENV:Client: No method Enter found>
>I have gone carefully through the py scripts adding 'print' markers to track
>this. The method Venue.Enter is never run or accessed, which is the one I am
>presuming should be kicking in at this point. Both VenueClient.enterVenue
>methods are accessed (toolkit and site_packages) up to and including the above
>code snippet, which fails.
>A print statement one line above this cope snippet in the VenueClient script to
>print Client.Handle(URL), outputs a text string of the https:// for our venue
>server. After that, nothing. Another print command for Client.Handle( URL
>).get_proxy() prints out some kind of stack address or similar bunch-o-numbers,
>whch I dont have to hand right now, but can get if important.
>In line with some other comments made on this list, I have installed a single
>system, with Ag2.0rc1, and tried to access the Ag2.0 final venue server with it,
>and this does work, and correctly reports a default set up. However, having
>looked at the amount of changes since RC1, especially in these venue 'states'
>and scripts, I am very doubtful theres any possible mixed use advisable.
>So, is this just a UK thing? Something amiss with UK E-Science certs mayhap?
>Some host or service certs we need to fix up? or a w2k/python mystery?
>Bye for now
>lewis
>Lewis Grantham LLB MSc
>Project Leader, Multimedia Unit
>Media Resources, UCL (University College London)
>Windeyer Building, Cleveland Street, London W1P 6DB
>Tel: (+44) 020 7679 9258 Fax: (+44) 020 7580 0995
>URL: http://www.ucl.ac.uk/mediares/mmedia
