[AG-TECH] Running from source on windows
    Eric Olson
    eolson at mcs.anl.gov
    Mon Jul  7 12:45:14 CDT 2003
Hi Sang,
I should warn you that the CVS code is always being modified and may not
always be in a working state.
If you know this and still want to use the code in CVS:
It looks like you correctly setup your environment to run from CVS.
It looks like there was a warning or error when you entered a venue, but
it didn't get displayed because of one of the changes I made last week.
I committed a change to fix the 'warningString' error in cvs.  If you
still have problems with it let me know.  Normally if you can't enter the
venue, an error message window should pop up.
Eric
On Thu, 3 Jul 2003, Sang Woo Han wrote:
> Greetings all,
> I've tried to run AG2 from source. The progress is as following.
> 1) Install rat and vic and set path
> 2) getting AG2 source code by means of CVS
> 3) create a directory to hold the configurations files
>     > mkdir cfg
> 4) Run the CvsSetup tool
>     > python AccessGrid/bin/CvsSetup.py --agdir AccessGrid --dst cfg
> 5) run batch file to set my path: AGTK_LOCATION, PYTHONPATH, and AGTK_INSTALL
>     > env-init.bat
> 6) cd AccessGrid/bin
>     python SetupVideo.py
> 7) python VenueClient.py --personalNode
> Then, VenueClient.py is running normally, so that I can see the VenueClient window.
> However, when I try to connect any venue server, VenueClient is stopped with the following error.
> C:\AccessGrid\bin>python VenueClient.py --personalNode
> info is  (<PyHANDLE at 29011088 (892)>, <PyHANDLE at 29011504 (896)>, 704, 1368)
> info is  (<PyHANDLE at 29014584 (900)>, <PyHANDLE at 29029208 (904)>, 1080, 780)
> In queue thread
> Traceback (most recent call last):
>   File "C:\AccessGrid\AccessGrid\VenueClientUIClasses.py", line 1058, in callAdd
> ress
>     self.application.venueClient.EnterVenue(venueUri, true)
>   File "C:\AccessGrid\AccessGrid\VenueClient.py", line 547, in EnterVenue
>     s.EnterVenue(URL, back, self.warningString, enterSuccess)
> AttributeError: VenueClient instance has no attribute 'warningString'
> How can I run the VenueClient normally?
> Sangwoo Han
> Networked Media Laboratory
> Dept. of Information and Communications
> Kwangju Institute of Science and Technology (KJIST)
> 1 Oryong-dong, Buk-gu, Gwangju 500-712 Republic of Korea
> Tel: +82-62-970-3136       Email: swhan at kjist.ac.kr
> Fax: +82-62-970-2204
