[AG-TECH] High res video streams, in AG VIC session
Allan Spale
aspale at evl.uic.edu
Mon Jan 27 18:46:57 CST 2003
Bob,
Have you been able to get Pinnacle DC10+ to work on Windows? I have had
no luck doing so because Pinnacle tech support says that this is not
possible (i.e. it cannot be used to stream video). Any suggestions or
ideas? Have you had this card work in a stable manner on Linux (and if
so, what version)?
Thanks for your time and patience.
Allan
EVL at UIC
node-op
On Fri, 24 Jan 2003, Robert Olson wrote:
> You can also use a Pinnacle DC10+ (or other cards supported by the
> mjpegtools folks, though last I looked there were some problems with the
> LML33 and thumbnails...) with the AG vic, which has a hardware jpeg capture
> module. AG windows vic also supports accelerated JPEG decode with the Intel
> JPEG library.
> --bob
> At 12:44 PM 1/24/2003 -0800, Andrew Swan wrote:
> >so that leaves jpeg. jpeg is of course more expensive in
> >terms of bandwidth and cpu cycles. but the good news is
> >you can actually use it today. if you're willing to spend
> >a few hundred dollars on new hardware (a linux media labs
> >hardware jpeg codec) and are willing to run some non-standard
> >ag software, you can get great quality with rtptv:
> > http://bmrc.berkeley.edu/~delco/rtptv/
> >if you have another machine with an lml board, you can decode
> >in hardware quite cheaply. alternatively, you can decode in
> >software with openmash vic but may not be able to keep up with
> >a full 30 fps stream (although if you have a new top of the
> >line cpu you'll probably come pretty close)
> >if you don't want to buy hardware or run rtptv, you can still
> >get higher resolution images with software encoded jpeg.
> >this definitely works in openmash vic -- i don't know if it
> >works or how well it works in agvic.
