[AG-TECH] High res video streams, in AG VIC session
Lawrence A. Rowe
Rowe at bmrc.berkeley.edu
Fri Jan 24 15:19:33 CST 2003
"Osland, CD (Chris)" wrote:
> Hi all,
> We're interested in sending and receiving video streams, preferably
> as part of a regular AG VIC session, that run at higher than the
> AG default VIC resolution (388x288 or somesuch?). We would be
> interested in 640x480, 768x576 and 1024x768.
> [BTW Some months ago one of the UK sites unknowingly switched to a
> different resolution on the fly; this has the spectacular effect
> of killing the display machines on all nodes in the VV.]
This is a known bug in ag/uclvic.
> 1. Is anyone currently using higher resolution already with
> whom we could test our ability to receive? Is this using
> a standard VIC or a modified one, either to send or to
> receive?
We have used RTPtv to generate high bitrate, high quality images (jpeg)
that
can be played by omvic. We haven't tested it on P4's, but on older P3's
you could pixel-double CIF images and the quality was better than
expected. You can try to decode full-sized images but I doubt you can
get 60 fields/second that is produced by RTPtv. Of course, you can
configure RTPtv to send different frame rates if you wanted to play with
this. This won't work with ag/uclvic because of the large image problem
mentioned above. We had to fix it in omvic to handle the RTPtv streams.
> 2. Is anyone else interested in taking part in such experiments,
> and if so, what is you main interest - live video, application
> sharing, ...? Also, what is you area of expertise?
We'd be happy to send you RTPtv streams to experiment with if you want.
> 3. Has anyone a concise idea of the current state of VIC and
> OpenMASH in this area? I don't know what has already been
> written or what remains to be done.
One of the last things I hope we can finish before the end of this
academic year is to complete an H.263 encoder/decoder that will produce
reasonable quality images at tolerable bitrates. The current omvic
source tree has two relevant codecs: h.263+ and h.263. the h.263+ code
is the code from uclvic. I'm not sure it works - i am playing with it
right now and it crashes both talking to another omvic and talking to
uclvic. still need to test it with agvic. the h.263 codec pair is
non-functional at the moment. the h.263 encoder works but is very
limited - just sends i-blocks for ever frame (i.e., jpeg-like images).
the h.263 decoder in the current source tree doesn't work, and from
looking at the code, i'm not sure it ever worked.
Before being layed off, Lloyd Lim had partially completed an h.263
decoder. I am checking that code in the OM source tree right now. I've
seen it decode some streams but it gets confused on some of the advanced
coding options produced by the Polycom units. I'm working with some
ugrads to fix the large image problem (still happens with h.263+ and
current h.263 code) and to improve the h.263 encoder. I assume we'll
fix bugs in the h.263 decoder as well. And, depending on how things go,
we'll add some more coding heuristics to improve the quality/bitrate.
Probably add some of the high payoff features from h.263+ and h.263++.
And FYI: we discovered that the uclrat/uclvic code does not support
audio/video synchronization even though it was advertised as doing so.
I have another student working to re-implement the mbus commmands in
omvic and to modify the synch algorithms to try to get synchronized
streams to work. Having already done this in RTPtv, we know how hard it
is to get this right while minimizing latency and guaranteeing 24-hour
synch. I doubt we'll get it to work as well as RTPtv, which still needs
more work to adapt to varying network delays.
Larry
Professor Lawrence A. Rowe Internet: Rowe at BMRC.Berkeley.EDU
Computer Science Division - EECS Phone: 510-642-5117
University of California, Berkeley Fax: 510-642-5615
Berkeley, CA 94720-1776 URL: http://bmrc.berkeley.edu/~larry
