[AG-TECH] Experience with Polycom Soundstation Premier EX?
Sugree Phatanapherom
g4465027 at ku.ac.th
Wed Jan 22 17:59:07 CST 2003
> So this is the echo canceller that comes with the iREZ kit. How do you
> actually get it to cancel. How do you set the reference.
This mic needs speaker reference in and gives speaker reference out. That
means the echo canceller module gets both voice from its mic and voice from
output speaker. I think it should be enough to cut echo off with automatic
adjustment of echo delay. Anyway, this mic remembers its position in the
room. I have to wait for a min after placing it on the right place. Then
don't move it until finish the conference. It can cover room space diameter
around 10 metres.
Note that the room must have low noise. In my case, I must turn off old
air-condition because it makes too much noise. This mic doesn't allow to
control noise level.
> On Tue, 2003-01-21 at 20:28, Sugree Phatanapherom wrote:
> > I'm using Gentner VTC AccuMic that is tabletop built-in echo canceller
> > microphone. It provides RCA jack to mono mic output and requires speaker
> > reference. Unfortunately, Gentner moved to ClearOne Communication and
they
> > discontinued this product.
> > Anyway, you can still buy it but no support by ClearOne right now.
> > http://www.microphones.com/prodpage.cfm?URLID=2497
> > ----- Original Message -----
> > From: "Frank Sweetser" <fs at wpi.edu>
> > To: <ag-tech at mcs.anl.gov>
> > Sent: Wednesday, January 22, 2003 5:08 AM
> > Subject: [AG-TECH] Experience with Polycom Soundstation Premier EX?
> > > Has anyone played around with the Polycom SoundStation Premier EX
http://www.polycom.com/products_services/products_groups/0,1422,pw-181-181-1
> > 4,00.html
> > > for use in a PIG? It claims to have a line level in and out, but all
of
> > the
> > > docs that they have are geared towards using it over a POTS line.
> > > Or, does anyone have any other good recomendations for a comparable
> > combination
> > > mic/speaker/auto gain controll/echo cancellation tabletop device?
> > > Frank Sweetser fs at wpi.edu
> > > WPI Network Engineer
> Ti Leggett <leggett at mcs.anl.gov>
