[AG-TECH] Experience with Polycom Soundstation Premier EX?
David Pennycuick
pennycui at usq.edu.au
Tue Jan 21 16:57:35 CST 2003
We use them on POTS.... They work well.
I have never seen a spec on echo canceller time range, but I suspect it would have trouble on high latency links...
In any case, I also suspect that the line in and out may bypass the EC since it is normally used for local recording, or input from non mic sources.
HTH
David
David Pennycuick
Technical Officer
University of Southern Queensland - Distance Education Centre
Technical Services Workshop.
Phone 07 4631 2017
Mobile 0419 282 374
Speed dial (on Campus) 7602
-----Original Message-----
Sent: Wednesday, 22 January 2003 8:09
To: ag-tech at mcs.anl.gov
Subject: [AG-TECH] Experience with Polycom Soundstation Premier EX?
Has anyone played around with the Polycom SoundStation Premier EX
http://www.polycom.com/products_services/products_groups/0,1422,pw-181-181-14,00.html
for use in a PIG? It claims to have a line level in and out, but all of the
docs that they have are geared towards using it over a POTS line.
Or, does anyone have any other good recomendations for a comparable combination
mic/speaker/auto gain controll/echo cancellation tabletop device?
Frank Sweetser fs at wpi.edu
WPI Network Engineer
