[AG-TECH] newer RedHat required. (fwd)
Leslie Arvin
arvin at stat.purdue.edu
Fri Jan 10 14:17:38 CST 2003
I have installed AG 1.0 on RedHat 8.0 and it appears to work.
I'm not done tweaking it yet.
Copying a working /usr/local/ag from a working RedHat 6.2 node
to a RedHat 8 machine worked immediately, though tweaking the
install helps (setting path, etc. -- look in
/usr/local/ag/lib/ag-install for AG 1.0 post-install steps).
And of course, I can't speak for your drivers.
-- Leslie Arvin
Programmer
Purdue University Access Grid
Randy Groves wrote:
> 7.3 also works - don't know about 8.0 yet.
> -randy
> At 02:43 PM 1/9/2003 -0500, Andrew Bolyea wrote:
>> Forgot to send this to ag-tech the first time.
>> -------- Original Message --------
>> Subject: Re: [AG-TECH] newer RedHat required
>> Date: Thu, 09 Jan 2003 12:09:39 -0500
>> From: Andrew Bolyea <andrew.bolyea at sheridanc.on.ca>
>> To: Andrew Shewmaker <shewa at inel.gov>
>> References: <20030109082155.42191db9.shewa at inel.gov>
>> Hi Andrew.
>> Quite some time ago I had to install RedHat 7.2 because 6.2 did not
>> support some new hardware. Then I installed all the RPMs required for
>> the AG (and everything seemed to work fine) :
>> ag-bttv-0.6.4h-2.i386.rpm
>> ag-install-1.0-5.i386.rpm
>> ag-scripts-1.0-3.i386.rpm
>> ag-vrm-1.06-1.i386.rpm
>> java-getopt-1.0.6-1.i386.rpm
>> job-3.3.2-1.i386.rpm
>> jre-1.2.2-4.i386.rpm
>> nlanr-beacon-0.63-1.i386.rpm
>> opensound-3.9.4g-1.i386.rpm
>> rtpmon-1.0a7-1.i386.rpm
>> ucl-nte-1.7.0-1.i386.rpm
>> ucl-rat-4.2.16-2.i386.rpm
>> ucl-rat-debug-4.2.16-2.i386.rpm
>> ucl-reflector-1.00-1.i386.rpm
>> ucl-sdr-2.6.3-1.i386.rpm
>> ucl-vic-2.8ucl1.1.3-5.i386.rpm
>> vtc-1.00-1.i386.rpm
>> xerces-j-1.1.3-1.i386.rpm
>> There may be more recent versions of these packages.
>> You may want to look at the following scripts, although again, I am
>> not sure how current they are:
>> http://ag-tech.mcs.anl.gov/reldb/repository/releases/agib/snapshots/snap-006/update
>> http://www-unix.mcs.anl.gov/~olson/AG/Software/Linux/RPMS/update
>> I hope this helps,
>> Andrew.
>> Andrew Bolyea
>> Sheridan College
>> Andrew Shewmaker` wrote:
>>> Hello,
>>> I am not allowed to use RedHat 6.2 due to security concerns, so I am
>>> wondering if anybody has made packages for RedHat 7.x or 8?
>>> Thanks,
>>> Andrew
