[AG-TECH] newer RedHat required
Impey, Roger
Roger.Impey at nrc-cnrc.gc.ca
Thu Jan 9 13:14:04 CST 2003
Hi:
Does any-one have a pointer to the ag-update.sh script? Sounds useful. I
looked at the mail achieve.
Roger Impey
-----Original Message-----
From: Gavin W. Burris aka 86 [mailto:ga5in at psu.edu]
Sent: Thursday, January 09, 2003 11:59 AM
To: Andrew Shewmaker`
Cc: Access Grid Technical mailing list
Subject: Re: [AG-TECH] newer RedHat required
Andrew Shewmaker` wrote (on Thu, 9 Jan 2003 at 08:21):
> I am not allowed to use RedHat 6.2 due to security concerns, so I am
> wondering if anybody has made packages for RedHat 7.x or 8?
I installed from a fresh ISO of Redhat 7.3, did security updates, then
installed all the Access Grid packages with the ag-update.sh script
someone posted a while back to get the 2001-08-16 22:28:00-05 snapshot
of RPMs.
These RPMs are found at:
http://ag-tech.mcs.anl.gov/reldb/repository/RPMS/i386/
All packages install fine, except for the reflector, which I've never
used. You will also have to move the defunct /usr/local/ag/jre1.2.2
out of the way, then download and install a newer build from
java.sun.com. Then all is well.
<<--=[ Gavin W. Burris aka 86 <ga5in at psu.edu> ]=-->>
<<--=[ Penn State Visualization Group Systems Programmer ]=-->>
<<--=[ http://viz.aset.psu.edu/ga5in ]=-->>
<<--=[ EOF ]=-->>
