[AG-TECH] WinGlobus cert problem
Thomas Uram
turam at mcs.anl.gov
Thu Feb 27 10:35:13 CST 2003
Randy:
You can find the "getting started" doc here:
http://scv.bu.edu/~jtvh/AGTk2/alpha02-getting-started.txt
Tom
Randy Heiland wrote:
>Woohoo - I'm in! It was indeed as simple as providing the filename for the
>proxy cert file (not sure why a default couldn't be supplied).
>Now that I've got everyone's attention, let me continue... :)
>I installed AGTk, then, after making sure I do a 'Grid Proxy Init' (and have a
>valid one), I try to do *something* with the AGTk. First, I see the menu ops
>that seem relevant to me are: Node Mgr, Venue Client, Venue Mgt, and Venue
>Server.
>These names are not an obvious mapping from what I was trying to use on Linux:
>% python AGServiceManager.py
>% python AGNodeService.py
>nevertheless, I run 'Venue Server' and get:
> Not starting datastore for venue: None does not exist
> Service running at https://<mymachine>:8000/VenueServer
>(I assume the missing datastore is OK and proceed...)
>then I try to run either 'Venue Client' or 'Venue Mgt' and give the URL for my
>service, but always get the 'venue URL no valid' msg (which is how far I was
>getting on Linux too).
>Is there a AGTk-for-dummies writeup somewhere? In an earlier post by Willing,
>he mentioned:
>>Based Jennifer's getting-started page (for Windows), I've run:
>can someone point me to this page?
>Other advice welcome.
>thanks,
>Randy
>On Feb 27, 8:19am, Ti Leggett wrote:
>>Subject: Re: [AG-TECH] WinGlobus cert problem
>>I really think the problem lies in something not being happy with the
>>truncated 8.3 paths with '~' in them. If you choose broswse and rechoose
>>just directory so it has the full path (eg, C:\Documents and
>>Setting....) it works. This stems from using %TEMP% which for some
>>reason truncates the paths.
>>On Thu, 2003-02-27 at 07:37, Shawn Davis wrote:
>>>At 06:45 AM 2/27/2003, Randy Heiland wrote:
>>>>I then run 'Grid Proxy Init' -> Create, enter my passphrase (as I used on
>>>>Linux), and get an error:
>>>> 952:error...:proxy_local_create:Problems creating proxy
>>>>file:.\gssapi_ssleay\sslutils.c:3088
>>>> Open failed for File=c:...\heiland\LOCALS~1\Temp
>>>>the "...heiland\Local Settings\Temp" dir does exist, but ???
>>>For the proxy location, you need to specify a filename in addition to a
>>>path. The file should not exist; you're simply specifying where it should
>>>store the proxy data.
>>>So something like "...heiland\Local Settings\Temp\proxy" would work.
>>>-Shawn
>>-- End of excerpt from Ti Leggett
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20030227/41d68952/attachment.htm>
