[AG-TECH] AG2 installed, what next?
Ti Leggett
leggett at mcs.anl.gov
Wed Feb 26 21:47:05 CST 2003
So running the globus that we've packaged on a RedHat 8.1 system is not
surprising to fail as I figure RH8.1 uses gcc3.2 and glibc-2.3. You
should download the SRPMs for gpt, globus, and pyglobus and build them
on your system first.
rpm --rebuild <foo.src.rpm>
Try that and then let me know what happens.
On Wed, 2003-02-26 at 21:37, Christoph Willing wrote:
> I have alpha3.1 installed on a fresh RH8.1 (phoebe) machine, also have a
> nice new usercert.pem in my .globus directory. What happens now?
> Based Jennifer's getting-started page (for Windows), I've run:
> /usr/bin/AGNodeService.py which claimed to start a service OK
> /usr/bin/AGServiceManager.py ditto
> /usr/bin/NodeManagement.py which brings up a gui, but adding
> the appropriate address into its "Attach to Node" widget gives the
> following error:
> [root at exp root]# /usr/bin/NodeManagement.py
> Traceback (most recent call last):
> File
> "/usr/lib/python2.2/site-packages/AccessGrid/NodeManagementUIClasses.py", line 367, in Attach
> self.UpdateHostList()
> File
> "/usr/lib/python2.2/site-packages/AccessGrid/NodeManagementUIClasses.py", line 467, in UpdateHostList
> self.serviceManagers = self.vc.GetServiceManagers()
> AttributeError: 'NoneType' object has no attribute 'GetServiceManagers'
> Maybe they were Windows specific commands (despite being in /usr/bin) so
> I also tried, based on Ti's earlier email:
> grid-proxy-init this gave Segmentation fault, no other clues
> VenueServer.py complains about "None does not exist" -
> [root at exp lib]# VenueServer.py
> HN: exp.vislab.usyd.edu.au EP: 8002 TP: 8004 DP: 8006
> Loading Venue:
> https://exp.vislab.usyd.edu.au:8000/Venues/000000f39d0f07d90081004e009d00af897
> Not starting datastore for venue: None does not exist
> Service running at: https://exp.vislab.usyd.edu.au:8000/VenueServer
> then:
> VenueManagement.py brings up gui, into which I enter the service
> (https://exp.vislab.usyd.edu.au:8000/VenueServer) which VenueServer.py
> started. However when I press the Go button, it pops up an "Invalid URL"
> notifier. Also when I press that Go button, the following output appears
> in the shell from which I started VenueManagement.py:
> [root at exp root]# VenueManagement.py
> File: c_rehash
> File: CA.pl
> File: CA.sh
> File: globus-sh-exec
> File: der_chop
> File: grid-cert-request
> File: globus-url-copy
> File: grid-cert-info
> File: grid-cert-renew
> File: globus-hostname
> File: openssl
> File: grid-change-pass-phrase
> File: grid-default-ca
> File: grid-proxy-destroy
> File: grid-proxy-info
> File: grid-proxy-init
> LINUX /usr/lib/globus/bin/grid-proxy-init
> File: globus-domainname
> Any pointers on what to do next please?
> chris
