[AG-TECH] Issue with RedHat 7.2, rat, and full duplex
Robert Olson
olson at mcs.anl.gov
Tue Feb 25 14:45:28 CST 2003
ah, that'd be the probelm. The delta is sort of a funky device. Notice that
it shows up as having separate input and output devices, not unified full
duplex in/out devices.
I think that for rat to work properly with this device it will require
modifications to the rat audio driver to use the different devices for
input and output.
--bob
At 03:42 PM 2/25/2003 -0500, David Bradford wrote:
>I don't know what Russ is running, but I have an M-Audio Delta
>1010lt. Here's the sndstat. Thanks, David.
>[ag at cism-ag-audio]# cat /dev/sndstat
>OSS/Linux 3.9.7f (C) 4Front Technologies 1996-2002
>License serial number: N02696502
>Drivers: ENVY24
>This copy of OSS is licensed to David Bradford
>Build: 2.4.19
>Card config:
>IC Ensemble ENVY24
>Audio devices:
>0: M Audio Delta 1010LT out1/2
>1: M Audio Delta 1010LT out3/4
>2: M Audio Delta 1010LT out5/6
>3: M Audio Delta 1010LT out7/8
>4: M Audio Delta 1010LT S/PDIF out
>5: M Audio Delta 1010LT in1/2
>6: M Audio Delta 1010LT in3/4
>7: M Audio Delta 1010LT in5/6
>8: M Audio Delta 1010LT in7/8
>9: M Audio Delta 1010LT S/PDIF in
>10: M Audio Delta 1010LT input from mon. mixer
>11: M Audio Delta 1010LT (all outputs)
>12: M Audio Delta 1010LT (all inputs)
>Synth devices:
>Midi devices:
>0: M Audio Delta 1010LT #1
>Timers:
>0: System clock
>Mixers:
>AUDIO FROM /proc/pci
> Bus 3, device 2, function 0:
> Multimedia audio controller: IC Ensemble Inc ICE1712 [Envy24] (rev 2).
> IRQ 5.
> Master Capable. Latency=32.
> I/O at 0xb000 [0xb01f].
> I/O at 0xb400 [0xb40f].
> I/O at 0xb800 [0xb80f].
> I/O at 0xbc00 [0xbc3f].
>-----Original Message-----
>From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
>Behalf Of Robert Olson
>Sent: Tuesday, February 25, 2003 3:20 PM
>To: bradford at bu.edu; ag-tech at mcs.anl.gov
>Cc: dab
>Subject: Re: [AG-TECH] Issue with RedHat 7.2, rat, and full duplex
>what card is it?
>what does cat /dev/sndstat say?
>--bob
>At 03:14 PM 2/25/2003 -0500, David Bradford wrote:
>>Greetings,
>> Russ Wolf has been helping me set up our audio machine, and we've
>> encountered a problem. As he has the exact same problem on one of his
>> machines with a different audio card and setup (I am using oss and he
>> built a driver into his kernel), we don't think it's an issue with the card.
>> When we try to start up rat-debug, we get:
>> 1736:mbus_config.c:661 using Addr:224.255.222.239 Port:47000
>> Scope:HOSTLOCAL for MBUS
>> 1736:process.c:83
>> PATH=/usr/local/ag/debug-bin:/bin:/usr/bin:/usr/local/bin:/sbin:/usr/sbin:/usr/local/ag/bin:.
>> 1737:main_ui.c:104 rat-ui started argc=5
>> 1737:mbus_config.c:661 using Addr:224.255.222.239 Port:47000
>> 1737:main_ui.c:118 Waiting for mbus.waiting(rat-token-761a2e82) from
>> controller...
>> 1737:main_ui.c:120 ...got it
>> 1737:main_ui.c:126 Waiting for mbus.go(rat-token-761a2e82) from
>> controller...
>> 1736:process.c:83
>> PATH=/usr/local/ag/debug-bin:/bin:/usr/bin:/usr/local/bin:/sbin:/usr/sbin:/usr/local/ag/bin:.:.
>> 1736:main_control.c:509 Waiting for rat-token-588e0344 from media
>> engine...
>> 1738:main_engine.c:88 token[0] = rat-token-588e0344
>> 1738:auddev_oss.c:185 device mask for /dev/mixer0:
>> 1738:auddev_oss.c:197 recording mask for /dev/mixer0:
>> 1738:auddev_oss.c:267 testing /dev/dsp0 support for full duplex
>> operation: no
>>Any ideas would be most welcome, as this seems to be the last issue
>>standing between me and a working grid node. Thanks in advance for any help,
>>David Bradford
>>Astronomy Department
>>Boston University
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20030225/663c39c6/attachment.htm>
