[AG-TECH] Issue with RedHat 7.2, rat, and full duplex
Colin Perkins
csp at isi.edu
Tue Feb 25 14:30:59 CST 2003
--> "David Bradford" writes:
>Greetings,
> Russ Wolf has been helping me set up our audio machine, and we've
>encountered a problem. As he has the exact same problem on one of his
>machines with a different audio card and setup (I am using oss and he built
>a driver into his kernel), we don't think it's an issue with the card.
> When we try to start up rat-debug, we get:
> 1736:mbus_config.c:661 using Addr:224.255.222.239 Port:47000 Scope:HOSTLOCAL for MBUS
> 1736:process.c:83 PATH=/usr/local/ag/debug-bin:/bin:/usr/bin:/usr/local/bin:/sbin:/usr/sbin:/usr/local/ag/bin:.
> 1737:main_ui.c:104 rat-ui started argc=5
> 1737:mbus_config.c:661 using Addr:224.255.222.239 Port:47000 Scope:HOSTLOCAL for MBUS
> 1737:main_ui.c:118 Waiting for mbus.waiting(rat-token-761a2e82) from controller...
> 1737:main_ui.c:120 ...got it
> 1737:main_ui.c:126 Waiting for mbus.go(rat-token-761a2e82) from controller...
> 1736:process.c:83 PATH=3D/usr/local/ag/debug-bin:/bin:/usr/bin:/usr/local/bin:/sbin:/usr/sbin:/usr/local/ag/bin:.:.
> 1736:main_control.c:509 Waiting for rat-token-588e0344 from media engine...
> 1738:main_engine.c:88 token[0] = rat-token-588e0344
> 1738:auddev_oss.c:185 device mask for /dev/mixer0:
> 1738:auddev_oss.c:197 recording mask for /dev/mixer0:
> 1738:auddev_oss.c:267 testing /dev/dsp0 support for full duplex operation: no
>Any ideas would be most welcome, as this seems to be the last issue standing
>between me and a working grid node. Thanks in advance for any help,
The linux device driver is telling rat that your soundcard does not support
full duplex operation. This is a common bug with the linux drivers.
You could try using the commercial OSS sound driver, or maybe ALSA. Or try
a different sound card.
Colin
