[AG-TECH] RE: Quad S-Video Capture Cards
    Impey, Roger
    Roger.Impey at nrc-cnrc.gc.ca
    Fri Feb 21 12:23:35 CST 2003
Hi:
The new cards do not need to be 64bit and/or 66Mhx, but as pointed out Ti
Leggett, they must be 3.3 volt compatible to fit the newer motherboards. I
am a little surprised about this all. Video and Ethernets cards have been
compatible for a while. (I have a 2 year old Matrox video card that is just
fine) So, why not the video capture cards, is it a problem with the chipset
(BT878)?
     Roger
-----Original Message-----
Sent: Friday, February 21, 2003 11:05 AM
Cc: 'ag-tech at mcs.anl.gov'
Subject: Re: [AG-TECH] RE: Quad S-Video Capture Cards
Roger is right. Our new video capture machine has only 3 available 32
bit/33 Mhz slots, so we would like to utilize the available 64 bit/66
Mhz slots for additional cameras. When we purchased the machine, any
information I could find online and Dell tech support told my that I
could use 32 bit cards in the 64 bit slots. I have since discovered that
this is theoretically possible, if only the cards would physically fit
in the slots. I've been on the lookout for an affordable 64 bit card
ever since. So, if anybody has any information on a solution, I, too
would appreciate it.
By the way, Roger - I'm almost glad you ran into this problem. I thought
maybe I was just being an idiot or suffered some serious brain damage
and wasn't putting the cards in right.
Darin
Impey, Roger wrote:
>Hi:
>So, I guess the answer to my question is "No".
>I have just ordered new machines that only have 64 bit/66 Mhz PCI slots. My
>current video capture cards will not fit. So, what to do?
>This is a problem we will all face sooner to later.
>      Roger
>From: Impey, Roger
>Sent: Thursday, February 20, 2003 9:06 AM
>To: ag-tech at mcs.anl.gov
>Subject: Quad S-Video Capture Cards
>Hi:
>Does anyone have any experience with a good quad input S-Video 66 Mhz
>compatible PCI capture card? For example, I don't believe the Spectra8
video
>capture card is 66 Mhz PCI slot compatible, or indeed, has S-video inputs.
>Failing this, how about a dual input card?
>    Roger
