[AG-TECH] RE: Quad S-Video Capture Cards
Ti Leggett
leggett at mcs.anl.gov
Fri Feb 21 11:04:07 CST 2003
Here's what we've seen. A lot of audio cards and capture cards are 32
bit/33 MHz which is fine. 64/66 slots are backwards compatible in this
respect. However there are two voltages that PCI cards can take. 3.3V or
5V. Most audio and capture cards I've seen are 5V (i.e., they don't have
the notch at the front of the card). A lot of 64/66 slots coming out now
support only 3.3V (i.e., they have a notch at the front of a card).
There are ways to use 5V card in a 3.3V slot using adapters and risers.
The company we've traditionally used has been Adex Electronice
(http://www.adexelec.com) though we haven't actually gotten 2 5V cards
to work using risers provided by them, we have gotten 1 card to work.
The techs there were always very helpful in trying to get us exactly
what we needed and if you have more time to work with them than I did at
the time, you'd probably get something that would work with 2 5V cards.
On Fri, 2003-02-21 at 09:33, Impey, Roger wrote:
> Hi:
> So, I guess the answer to my question is "No".
> I have just ordered new machines that only have 64 bit/66 Mhz PCI slots. My
> current video capture cards will not fit. So, what to do?
> This is a problem we will all face sooner to later.
> Roger
> -----Original Message-----
> From: Impey, Roger
> Sent: Thursday, February 20, 2003 9:06 AM
> To: ag-tech at mcs.anl.gov
> Subject: Quad S-Video Capture Cards
> Hi:
> Does anyone have any experience with a good quad input S-Video 66 Mhz
> compatible PCI capture card? For example, I don't believe the Spectra8 video
> capture card is 66 Mhz PCI slot compatible, or indeed, has S-video inputs.
> Failing this, how about a dual input card?
> Roger
Ti Leggett <leggett at mcs.anl.gov>
