[AG-TECH] Compiling VIC from source to enable High-res streams
S.Booth
spb at epcc.ed.ac.uk
Thu Feb 20 09:34:41 CST 2003
I have been trying to modify the ag-vic source from
:pserver:anonymous at fl-cvs.mcs.anl.gov:/cvsroot/ag-vic
to enable higher res video streams using the h263+ codec.
(My current version of a patch to do this is attached)
In the original code there were various statically sized buffers that were
only large enough for normal image sizes.
It seems to work up to a point (for some reason the thumbnails don't work
when sending a large image size stream but this seems to be a
generic problem as the same happens with the bvc codec as well.
However the main problem is that vic runs VERY VERY slowly compared with
the normal ag vic (vic-2001-0601) and the h.261 codec seems broken!
Are there some debug flags I should be turning off or is this a problem
with the compiler version I'm using?
I'm using
gcc version 2.96 20000731 (Red Hat Linux 7.3 2.96-110)
Stephen
|epcc| Dr Stephen P Booth Project Manager |epcc|
|epcc| s.booth at epcc.ed.ac.uk Phone 0131 650 5746 |epcc|
Index: codec/decoder-h263v2.cpp
RCS file: /cvsroot/ag-vic/vic/codec/decoder-h263v2.cpp,v
retrieving revision 1.1.1.1
diff -r1.1.1.1 decoder-h263v2.cpp
3a4
> #include <assert.h>
10c11,12
> #define FRAMESIZE 1600000
> #define BITSSSIZE 65536
30c32,33
< char bitstream[65536]; /* bitstream data */
> char *bitstream; /* bitstream data */
> int bsize;
37c40
< u_char xxx_frame[160000];
> u_char xxx_frame[FRAMESIZE];
78a82,83
> bitstream = (char *) 0;
> bsize = 0;
87a93,96
> if( bitstream ){
> free(bitstream);
152a162
159a170,177
> if( bsize == 0 ){
> bitstream = (char *) malloc(BITSSSIZE);
> if( ! bitstream ){
> perror("malloc failed");
> exit(1);
> bsize=BITSSSIZE;
187a206,218
> /* grow buffer */
> if(b_off+(cc-bs) > bsize){
> while(b_off+(cc-bs) > bsize){
> bsize *=2;
> fprintf(stderr,"realloc bitstream %d\n",bsize);
> bitstream = (char *) realloc(bitstream,bsize);
> if( ! bitstream ){
> perror("realloc failed");
> exit(1);
198a230,241
> /* grow buffer */
> if(b_off+3 > bsize){
> while(b_off+3 > bsize){
> bsize *=2;
> if( ! bitstream ){
> exit(1);
211a255
> assert(size <= FRAMESIZE);
212a257
> assert(size + size/4 <= FRAMESIZE);
213a259
> assert(size*5/4 + size/4 <= FRAMESIZE);
Index: codec/encoder-h263v2.cpp
RCS file: /cvsroot/ag-vic/vic/codec/encoder-h263v2.cpp,v
diff -r1.1.1.1 encoder-h263v2.cpp
40a41
> #include <assert.h>
59a61,66
> #define CIF4_WIDTH 704
> #define CIF4_HEIGHT 576
> #define CIF16_WIDTH 1408
> #define CIF16_HEIGHT 1152
69a77
> extern "C" int h263_bitstream_size;
125a134
> /* These seem to be values CIF/CIF4 etc from tmn/sim.h */
129a139,142
> } else if (w == CIF4_WIDTH && h == CIF4_HEIGHT) {
> state->pic->source_format = 4;
> } else if (w == CIF16_WIDTH && h == CIF16_HEIGHT) {
> state->pic->source_format = 5;
185a199,200
> h263_bitstream=(char *) 0;
> h263_bitstream_size = 0;
192a208
> h263_bitstream_size = 65536;
231a248,249
> assert(ps + 14 <= RTP_MTU);
> assert(ps+n <= h263_bitstream_size);
Index: codec/tmn/putbits.c
RCS file: /cvsroot/ag-vic/vic/codec/tmn/putbits.c,v
diff -r1.1.1.1 putbits.c
69c69,70
< unsigned char *h263_bitstream;
> unsigned char *h263_bitstream=(char *) 0;
> int h263_bitstream_size=0;
118a120,123
> if( h263_streamcount >= h263_bitstream_size ){
> h263_bitstream_size *= 2;
> h263_bitstream = (char *) realloc(h263_bitstream,h263_bitstream_size);
Index: codec/tmn-x/putbits.c
RCS file: /cvsroot/ag-vic/vic/codec/tmn-x/putbits.c,v
69c69,70
118a120,124
> fprintf(stderr,"realloc to %d\n",h263_bitstream_size);
Index: tcl/cf-util.tcl
RCS file: /cvsroot/ag-vic/vic/tcl/cf-util.tcl,v
diff -r1.1.1.1 cf-util.tcl
195c195
< puts "resrouce $r $V(class)"
> # puts "resrouce $r $V(class)"
