[AG-TECH] Running Venues Server Alpha2
Michael Daw
mike.daw at man.ac.uk
Mon Feb 17 10:02:38 CST 2003
If I run 'grid-proxy-init -debug', I get:
[root at george bin]# grid-proxy-init -debug
Files being used:
cert_file: none
cert_dir : /etc/grid-security/certificates
proxy : /tmp/x509up_u0
user_cert: none
user_key : none
Segmentation fault
Looking at http://www.globus.org/gt2/install/index.html#verify, I notice
that this is the first command to verify my installation, with no pointers
on what to do if it fails.
(By the way, I've reopened bug #25, because
http://www-unix.mcs.anl.gov/fl/research/accessgrid/software/developers/index
.html is still pointing at the original, wrong, web page.)
--Mike
> -----Original Message-----
> From: Ivan R. Judson [mailto:judson at mcs.anl.gov]
> Sent: 17 February 2003 15:01
> To: 'Michael Daw'; 'AG Technical Developers'
> Subject: RE: [AG-TECH] Running Venues Server Alpha2
> Ah the beauty of software releases.
> Here's a Quick Start:
> 1) Get proxy credentials :-)
> This is either grid-proxy-init on linux, or wgpi.exe on windows.
> 2) run VenueServer.py
> This is the actual venue server. It defaults to listening for
> connections on port 8000 but that's also an argument that can be passed on
> the command-line (if I remember right).
> 3) run VenueManagement.py
> This is the management UI. You point it at your venue server which
> is a url of the form: https://host:port/VenueServer, I'll explain
> this in a
> bit more detail. The URL has to start with https, we're doing
> secure stuff.
> The host:port should be obvious, it is a URL. The VenueServer is
> the service
> at that host:port that you are connecting to.
> See if that gets you started!
> --Ivan
> > From: owner-ag-tech at mcs.anl.gov
> > [mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Michael Daw
> > Sent: Monday, February 17, 2003 8:16 AM
> > To: AG Technical Developers
> > Subject: [AG-TECH] Running Venues Server Alpha2
> > I've downloaded and installed the RPMs
> > AccessGrid-2.0alpha-2.i386.rpm and
> > AccessGrid-VenueServer-2.0alpha-2.i386.rpm.
> > I'm not sure what I need to do to run the Venue Server.
> > Here's what I guessed at:
> > Run /usr/bin/VenueManagement.py
> > This gets me an interesting looking GUI. When I press 'Go',
> > these are the last few lines of output:
> > File
> > "/var/tmp/pyGlobus-cvs/usr/lib/python2.2/site-packages/pyGlobu
> > s/io.py", line 658, in connect
> > pyGlobus.io.GSITCPSocketException: authentication failed:
> > Problem with local credentials
> > GSS status: major:00070000 minor: 000003fd token: 00000000
> > I didn't want to report a bug, because I suspect there's
> > something I should be doing before this ("authentication
> > failed" seems like a giveaway...).
> > _______________________________________________________
> > Michael Daw
> > SVE Group (Supercomputing, Visualization and e-Science)
> > Manchester Computing, Kilburn Building,
> > University of Manchester, Manchester M13 9PL, UK
> > Tel: +44 (0)161 275 7026
> > Fax: +44 (0)161 275 6800
> > Email: michael.daw at man.ac.uk
> http://www.sve.man.ac.uk/General/Staff/daw
