[AG-TECH] Running Venues Server Alpha2
Michael Daw
mike.daw at man.ac.uk
Mon Feb 17 08:16:14 CST 2003
I've downloaded and installed the RPMs AccessGrid-2.0alpha-2.i386.rpm and
AccessGrid-VenueServer-2.0alpha-2.i386.rpm.
I'm not sure what I need to do to run the Venue Server.
Here's what I guessed at:
Run /usr/bin/VenueManagement.py
This gets me an interesting looking GUI. When I press 'Go', these are the
last few lines of output:
File
"/var/tmp/pyGlobus-cvs/usr/lib/python2.2/site-packages/pyGlobus/io.py", line
658, in connect
pyGlobus.io.GSITCPSocketException: authentication failed:
Problem with local credentials
GSS status: major:00070000 minor: 000003fd token: 00000000
I didn't want to report a bug, because I suspect there's something I should
be doing before this ("authentication failed" seems like a giveaway...).
_______________________________________________________
Michael Daw
SVE Group (Supercomputing, Visualization and e-Science)
Manchester Computing, Kilburn Building,
University of Manchester, Manchester M13 9PL, UK
Tel: +44 (0)161 275 7026
Fax: +44 (0)161 275 6800
Email: michael.daw at man.ac.uk
http://www.sve.man.ac.uk/General/Staff/daw
