[AG-TECH] Multicast Address Use in AG2
Ivan R. Judson
judson at mcs.anl.gov
Tue Feb 11 11:27:20 CST 2003
The Venue Server will support static addressing. You are welcome (and
encouraged) to run a venue server configured whatever way you'd like. Just
remember, addresses might get scarce before we move to IPv6 and it's a best
practices area. We all have to do our best with resource stewardship.
--Ivan
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov
> [mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Randy Groves
> Sent: Tuesday, February 11, 2003 10:21 AM
> To: 'Sergeant A. G. Tech'
> Subject: RE: [AG-TECH] Multicast Address Use in AG2
> Am I to assume, however, that the capability to create
> statically allocated
> venues won't disappear from the AG2 code? Could we at Boeing
> create a
> venue server with statically allocated addresses using the AG2 code
> base? That it is just the support of such a static and
> transitional venue
> server that is going away?
> -randy
> At 09:21 AM 2/11/2003 -0600, Ivan R. Judson wrote:
> > > > 2) We will host a transitional AG2 Venue Server that is
> > > > initialized with the AG1 venues (same name,
> description, topology,
> > > > and media
> > > > streams) so that AG2
> > > > users can collaborate with AG1 users. We will get this
> > > built as soon as
> > > > possible.
> > > It might be that my question has been answered implicitly
> in Ivan's
> > > message, but that I just don't know enough to realize that :)
> > > So, there is currently a fairly large set of static IP
> assignments
> > > courtesy of ANL - current institutions seem to have their
> own pairs,
> > > along with the traditional venues. Will these static assignments
> > > ultimately vanish after the transition, or will this new policy
> > > apply only to new, future venues? Or, somewhere in between (e.g.
> > > retain things like Test Room and AG Lobby as statically
> assigned IP
> > > pairs)?
> >Yes, after the transition the current static addresses in
> the current
> >venues will vanish. It might be advantageous to keep the venues
> >themselves for familiarity.
> >The transition will take a long time (in computer time) --
> things won't
> >vanish until at least after SCGlobal. Perhap early 2004, but
> they will
> >go away eventually, unless somehow magically we get some operational
> >support infrastructure (people and money).
> >Sorry that wasn't more clear.
> >--Ivan
