[AG-TECH] AG 2.1.2 install can't contact venue server
Thomas D. Uram
turam at mcs.anl.gov
Tue Dec 16 11:46:40 CST 2003
Phil:
There was a problem with the eScience CA cert on the transitional venue
server. I've reimported the certificate, and it should work fine now.
Let me know if there is still a problem.
Tom
Phil Stanford wrote:
>I've done an installation on a Windows 2000 machine of AG2.1.2 as a PIG.
>I'm having problems with the Venue Client connecting to the default Venue
>Server.
>I'm getting 'No reachable venue at given venue URL' and 'Authorisation
>failure' as per the trace below.
>I'm using a UK e-Science certificate, but I think that the proxy cert is
>being set up OK
>I don't *think* it's a firewalling issue as an Ethereal trace (capture
>file available if it'll help) does show the venue client contacting the
>server on port 9000 and a brief conversation ensues, during which I can
>see the plain-text bits of my cert being sent to the server.
>I'm sure it's a very silly mistake on my part but I'd welcome clues ...
>Thanks
>Phil
>12/15/03 16:29:05 DEBUG Creating thread 0
>12/15/03 16:29:05 DEBUG Starting thread 0
>12/15/03 16:29:05 DEBUG Worker 0 starting
>12/15/03 16:29:05 DEBUG Waiting thread 0
>12/15/03 16:29:05 DEBUG Done creating workers
>12/15/03 16:29:05 DEBUG Reading persisted data from: C:\Documents and
>Settings\p
>ns\Application Data\AccessGrid\personalDataStore\DataStore.dat
>C:\PROGRA~1\ACCESS~2\bin\agpm.py:57: RuntimeWarning: tmpnam is a potential
>secur
>ity risk to your program
> workingDir = os.path.join(GetTempDir(), os.path.basename(os.tmpnam()))
>secur
>12/15/03 16:29:15 DEBUG userConfigDir: C:\Documents and
>Settings\pns\Application
> Data\AccessGrid
>12/15/03 16:29:15 DEBUG Opened repository C:\Documents and
>ion Data\AccessGrid\certRepo
>12/15/03 16:29:15 DEBUG Unlink C:\Documents and Settings\pns\Application
>Data\Ac
>cessGrid\trustedCACerts\42864e48.signing_policy
>Data\Ac
>cessGrid\trustedCACerts\45cc9e80.signing_policy
>Data\Ac
>cessGrid\trustedCACerts\01621954.0
>Data\Ac
>cessGrid\trustedCACerts\01621954.signing_policy
>Data\Ac
>cessGrid\trustedCACerts\42864e48.0
>Data\Ac
>cessGrid\trustedCACerts\45cc9e80.0
>12/15/03 16:29:15 DEBUG Using default identity
>/C=UK/O=eScience/OU=Southampton/L
>=SOC/CN=phil stanford
>12/15/03 16:29:15 DEBUG Initializing environment with proxy cert for
>/C=UK/O=eSc
>ience/OU=Southampton/L=SOC/CN=phil stanford
>12/15/03 16:29:15 DEBUG Configuring for user proxy issued from
>/C=UK/O=eScience/
>12/15/03 16:29:15 DEBUG Proxy C:\DOCUME~1\pns\LOCALS~1\Temp\x509_up_pns
>will exp
>ire 12/15/03 18:54:40
>12/15/03 16:29:15 DEBUG bin.VenueClient::OnInit: ispersonal=1
>AGServiceManager URL: https://152.78.109.40:12000/ServiceManager
>Running Service; options: C:\Python22\python.exe [u'C:\\Documents and
>Settings\\
>pns\\Application Data\\AccessGrid\\local_services\\AudioService.py',
>50848]
>Trying client handle
>Wait another sec for service to boot
> - elapsedTries = 0
> - elapsedTries = 1
> - elapsedTries = 2
>Starting server at https://152.78.109.40:50848/Service
>* * Service handle is valid !
>Settings\\
>pns\\Application
>Data\\AccessGrid\\local_services\\VideoConsumerService.py', 501
>88]
> - elapsedTries = 0
> - elapsedTries = 1
> - elapsedTries = 2
>Starting server at https://152.78.109.40:50188/Service
>12/15/03 16:29:47 DEBUG bin.VenueClient::OnInit: setting node service
> URI to https://localhost:11000/NodeService from
>PersonalNode
>12/15/03 16:29:47 DEBUG bin.VenueClient: SetProfile
>AGNodeService URL: https://152.78.109.40:11000/NodeService
>12/15/03 16:30:16 DEBUG HaveValidProxy: found proxy ident
>uthampton/L=SOC/CN=phil stanford/CN=proxy
>12/15/03 16:30:16 DEBUG Set history url: None
>12/15/03 16:30:27 ERROR AccessGrid.VenueClient::EnterVenue failed; time is
>okay
>(offset=0
>Traceback (most recent call last):
> File "C:\Python22\Lib\site-packages\AccessGrid\VenueClient.py", line
>458, in E
>nterVenue
> Client.Handle( URL ).IsValid()
> File
>"C:\Python22\Lib\site-packages\AccessGrid\hosting\pyGlobus\Client.py", li
>ne 83, in IsValid
> ret = proxy._IsValid()
> File
>"C:\Python22\Lib\site-packages\AccessGrid\hosting\pyGlobus\AGGSISOAP.py",
> line 3660, in __call__
> return self.__r_call(*args, **kw)
> File
> line 3680, in __r_call
> self.__hd, self.__ma)
> File
> line 3580, in __call
> config = self.config)
> File
>ne 188, in call
> r.endheaders()
> File "C:\Python22\lib\httplib.py", line 695, in endheaders
> self._send_output()
> File "C:\Python22\lib\httplib.py", line 581, in _send_output
> self.send(msg)
> File "C:\Python22\lib\httplib.py", line 548, in send
> self.connect()
> File "C:\Python22\Lib\site-packages\pyGlobus\io.py", line 1084, in
>connect
> self.sock.connect(self.host, self.port, self.io_attr)
> File "C:\Python22\Lib\site-packages\pyGlobus\io.py", line 663, in
>connect
> raise ex
>GSITCPSocketException: an authentication operation failed
>466, in E
>nterVenue
> raise EnterVenueException("No reachable venue at given venue URL")
>EnterVenueException: No reachable venue at given venue URL
>12/15/03 16:30:27 DEBUG bin.VenueClient::EnterVenue: Enter venue with url:
>https
>://vv2.mcs.anl.gov:9000/Venues/default
>12/15/03 16:30:30 DEBUG Authorization failure connecting to server.
