[AG-TECH] Single computer node and good projectors
George Estes
gestes at ncsa.uiuc.edu
Thu Dec 11 09:12:11 CST 2003
Our Sharp projectors need a new lamp about every 1000 hours of use, more or
less.
At 02:21 PM 12/11/2003 +0000, you wrote:
>No bulb replacements?! Wow. Our Epsons require new bulbs about once a year.
>Considering their expense (£300 / $500ish for each bulb), this is quite a
>problem. Is it just the Epsons that need so many new bulbs or is it that we
>just use them more than you...?
> > -----Original Message-----
> > From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov]On
> > Behalf Of Osland, CD (Chris)
> > Sent: 11 December 2003 13:17
> > To: 'DAAgarwal at lbl.gov'; ag-tech at mcs.anl.gov
> > Subject: RE: [AG-TECH] Single computer node and good projectors
> > Personally, I think I've been responsible for the purchase of
> > about 14 projectors and to a first approximation:
> > none has required a bulb replacement
> > one had the LCD panel go soft and green
> > all (except the last 7) have been superceded because newer
> > projectors were brighter, more capable (w.r.t. resolution,
> > interfaces etc.) or quieter - the older machines were not
> > worth any work to renovate them.
> > These projectors have had one of three roles:
> > service projector in heavily used meeting rooms
> > service projectors in stereoscopic VR cinemas
> > portable projectors for off-site (or across-site) use
> > We've used InFocus, LitePro, Panasonic, Sony, Sharp and
> > Electrohome projectors - not really much between them over
> > the years, although I quite like the Panasonics at the
> > moment.
> > Cheers
> > Chris
> > ____________________________________________________________________
> > Chris Osland Office tel: +44
> > (0) 1235 446565
> > Digital Media and Access Grid Medialab
> > tel: +44 (0)
> > 1235 446459
> > BIT Department Access Grid
> > room tel: +44
> > (0) 1235 445666
> > e-mail: C.D.Osland at rl.ac.uk
> > Fax: +44
> > (0) 1235 445597
> > CLRC Rutherford Appleton Laboratory (Bldg. R18)
> > Chilton, DIDCOT, Oxon OX11 0QX, UK
> > [The contents of this email are confidential and are for the use of the
> > intended recipient only.
> > If you are not the intended recipient do not take any action on it or show
> > it to anyone else,
> > but return this email to the sender and delete your copy of it.]
> > > From: Deb Agarwal [mailto:DAAgarwal at lbl.gov]
> > > Sent: 10 December 2003 21:53
> > > To: ag-tech at mcs.anl.gov
> > > Subject: [AG-TECH] Single computer node and good projectors
> > > We at LBNL are very interested in the answers to both the
> > > question of a good single computer to run a AG node and
> > > the question of which projectors people are using.
> > > We just looked at buying new projectors for our node and
> > > one of our people came up with an incredibly short mean
> > > time between failures for the projectors. Could people responding
> > > with projector suggestions also give some information
> > > regarding the lifecycle costs they have experienced and
> > > the mean time between failures (including bulbs).
> > > Thanks,
> > > Deb
> > > Deb Agarwal e-mail:DAAgarwal at lbl.gov
> > > MS50B-2239 phone :(510)486-7078
> > > Lawrence Berkeley National Lab URL: http://www-itg.lbl.gov/~deba
> > > Berkeley, CA 94720
