[AG-TECH] AGTk 2.1.1b released
    Mike Weaver
    weaver at er.doe.gov
    Fri Aug 29 13:39:54 CDT 2003
I too had this problem.  Freshly built XP box.  Copied msvcr70.dll from
another box and clicked "Retry" and all seemed happy from there on.
Mike
----- Original Message -----
To: <judson at mcs.anl.gov>
Cc: <ag-tech at mcs.anl.gov>
Sent: Wednesday, August 27, 2003 19:39
Subject: Re: [AG-TECH] AGTk 2.1.1b released
> Hi,
> Still having the same problem with AGTk2.1.1b as I had with
AGTk2.1.1a:
> Error
> An error occurred while trying to read the source file:
> The source file "C:\WINNT\system32\msvcr70.dll" does not exist.
> But here is a quick fix:
> I skipped the install of this file which does exist in 2 other places
on my
> machine:
> C:\WINNT\Microsoft.NET\Framework\v1.0.3705
> C;\WINNT\system32\URTTemp
> 336kb 1/5/2002 4:37 AM
> I copied the file over to C:\WINNT\system32 - and the install was able
to
> complete - no errors.
> I guess that is good news?
> Joe Reitzer
> TRECC
> At 05:19 PM 8/27/2003 -0500, you wrote:
> >In response to a couple of errors in 2.1.1a we have packaged and
released
> >2.1.1b. This release fixes the installation warning about registering
the
> >dll, and it fixes some internal bugs that resulted in a failure to
start the
> >Venue Client in personal node mode.
> >It is available at:
>http://www-unix.mcs.anl.gov/fl/research/accessgrid/software/releases/2.
1.1/w
> >indows.html
> >This is a windows only update.
> >There is currently a known issue with installing the agtk as the
> >administrator, then subsequently using it as a normal user. We are
> >investigating this issue.
> >--Ivan
