[AG-TECH] AGTk 2.1.1b released
    Joe Reitzer
    joer at ncsa.uiuc.edu
    Wed Aug 27 18:39:09 CDT 2003
Still having the same problem with AGTk2.1.1b as I had with AGTk2.1.1a:
Error
An error occurred while trying to read the source file:
The source file "C:\WINNT\system32\msvcr70.dll" does not exist.
But here is a quick fix:
I skipped the install of this file which does exist in 2 other places on my
machine:
C:\WINNT\Microsoft.NET\Framework\v1.0.3705
C;\WINNT\system32\URTTemp
336kb 1/5/2002 4:37 AM
I copied the file over to C:\WINNT\system32 - and the install was able to
complete - no errors.
I guess that is good news?
Joe Reitzer
TRECC
At 05:19 PM 8/27/2003 -0500, you wrote:
>In response to a couple of errors in 2.1.1a we have packaged and released
>2.1.1b. This release fixes the installation warning about registering the
>dll, and it fixes some internal bugs that resulted in a failure to start the
>Venue Client in personal node mode.
>It is available at:
>http://www-unix.mcs.anl.gov/fl/research/accessgrid/software/releases/2.1.1/w
>indows.html
>This is a windows only update.
>There is currently a known issue with installing the agtk as the
>administrator, then subsequently using it as a normal user. We are
>investigating this issue.
>--Ivan
