[AG-TECH] AGTk 2.1.1b released
Joe Reitzer
joer at ncsa.uiuc.edu
Thu Aug 28 10:10:28 CDT 2003
Hi Ivan,
Yes I did install as Administrator. The install program will only let you
install it as Administrator.
The same thing George Estes wrote about. The install was on a W2K machine.
Joe
At 09:20 PM 8/27/2003 -0500, Ivan R. Judson wrote:
>Hey Joe,
>Did you install this as as administrator? The 2.1.1b installer copies the
>file to the windows\system32 directory, but as Sam pointed out in his mail
>it should more correctly be installed with the program that wants it. We're
>continuing to track this down. As of 2.1.1b however, we haven't had it fail
>-- odd.
>--Ivan
> > -----Original Message-----
> > From: Joe Reitzer [mailto:joer at ncsa.uiuc.edu]
> > Sent: Wednesday, August 27, 2003 6:39 PM
> > To: judson at mcs.anl.gov
> > Cc: ag-tech at mcs.anl.gov
> > Subject: Re: [AG-TECH] AGTk 2.1.1b released
> > Hi,
> > Still having the same problem with AGTk2.1.1b as I had with
> > AGTk2.1.1a:
> > Error
> > An error occurred while trying to read the source file:
> > The source file "C:\WINNT\system32\msvcr70.dll" does not exist.
> > But here is a quick fix:
> > I skipped the install of this file which does exist in 2
> > other places on my
> > machine:
> > C:\WINNT\Microsoft.NET\Framework\v1.0.3705
> > C;\WINNT\system32\URTTemp
> > 336kb 1/5/2002 4:37 AM
> > I copied the file over to C:\WINNT\system32 - and the install
> > was able to
> > complete - no errors.
> > I guess that is good news?
> > Joe Reitzer
> > TRECC
> > At 05:19 PM 8/27/2003 -0500, you wrote:
> > >In response to a couple of errors in 2.1.1a we have packaged and
> > >released 2.1.1b. This release fixes the installation warning about
> > >registering the dll, and it fixes some internal bugs that
> > resulted in a
> > >failure to start the Venue Client in personal node mode.
> > >It is available at:
> > >http://www-unix.mcs.anl.gov/fl/research/accessgrid/software/r
>eleases/2.
> >1.1/w
> >indows.html
> >This is a windows only update.
> >There is currently a known issue with installing the agtk as the
> >administrator, then subsequently using it as a normal user. We are
> >investigating this issue.
> >--Ivan
