[AG-TECH] AGTk 2.1.1b released
Ivan R. Judson
judson at mcs.anl.gov
Wed Aug 27 21:20:01 CDT 2003
Hey Joe,
Did you install this as as administrator? The 2.1.1b installer copies the
file to the windows\system32 directory, but as Sam pointed out in his mail
it should more correctly be installed with the program that wants it. We're
continuing to track this down. As of 2.1.1b however, we haven't had it fail
-- odd.
--Ivan
> -----Original Message-----
> From: Joe Reitzer [mailto:joer at ncsa.uiuc.edu]
> Sent: Wednesday, August 27, 2003 6:39 PM
> To: judson at mcs.anl.gov
> Cc: ag-tech at mcs.anl.gov
> Subject: Re: [AG-TECH] AGTk 2.1.1b released
> Hi,
> Still having the same problem with AGTk2.1.1b as I had with
> AGTk2.1.1a:
> Error
> An error occurred while trying to read the source file:
> The source file "C:\WINNT\system32\msvcr70.dll" does not exist.
> But here is a quick fix:
> I skipped the install of this file which does exist in 2
> other places on my
> machine:
> C:\WINNT\Microsoft.NET\Framework\v1.0.3705
> C;\WINNT\system32\URTTemp
> 336kb 1/5/2002 4:37 AM
> I copied the file over to C:\WINNT\system32 - and the install
> was able to
> complete - no errors.
> I guess that is good news?
> Joe Reitzer
> TRECC
> At 05:19 PM 8/27/2003 -0500, you wrote:
> >In response to a couple of errors in 2.1.1a we have packaged and
> >released 2.1.1b. This release fixes the installation warning about
> >registering the dll, and it fixes some internal bugs that
> resulted in a
> >failure to start the Venue Client in personal node mode.
> >It is available at:
> >http://www-unix.mcs.anl.gov/fl/research/accessgrid/software/r
eleases/2.
>1.1/w
>indows.html
>This is a windows only update.
>There is currently a known issue with installing the agtk as the
>administrator, then subsequently using it as a normal user. We are
>investigating this issue.
>--Ivan
