[AG-TECH] Certificates
Randy Groves
randy.groves at boeing.com
Fri Aug 29 12:23:56 CDT 2003
Essentially, it needs to be specified. In our particular case, the setups
are well known, and prevalent. I tend to point my machines to a specific
address (which is probably multi-hosted), but we also use some sort of
'pac' file that does configuration for the browsers (I don't use it, so I
don't know the impact there) - but the upshot is that on Windows, you
should be able to get the proxy info from the Internet Options. On Unix,
you'd have to depend on the appropriate settings of environment variables.
Of course, the fact that we're behind firewalls and web proxies create a
whole host of other problems ...
-randy
At 06:59 AM 8/29/2003 -0500, Robert Olson wrote:
>At 09:49 AM 8/28/2003 -0700, Randy Groves wrote:
>>I put in a bug report on this - there is a problem for people like myself
>>who are behind a web proxy. The certificate request process makes the
>>assumption that there is a clear shot to the web server.
>Good catch, it does indeed. Do you need to explicitly define your proxy
>server in your environment, or is there transparent proxying going on?
>--bob
