[AG-TECH] Sharing Handwritten Presentation Slides on AG ?
Ivan R. Judson
judson at mcs.anl.gov
Wed Aug 20 06:35:25 CDT 2003
Hey Jay,
This might be trivial given your command line tools. Let me get my head
around your email after my first cup of coffee and see what I can come up
with.
I think it'd be a great thing to use presenter within the AG.
--Ivan
> -----Original Message-----
> From: Jay Beavers [mailto:jbeavers at microsoft.com]
> Sent: Wednesday, August 20, 2003 1:10 AM
> To: judson at mcs.anl.gov; Stuart Levy; daagarwal
> Cc: ag-tech at mcs.anl.gov
> Subject: RE: [AG-TECH] Sharing Handwritten Presentation Slides on AG ?
> Thanks Ivan.
> I'd be interested in talking details about some
> infrastructure work that would allow Classroom Presenter (and
> our ConferenceApi) to derive the venue settings from an AG
> 2.1 environment.
> The biggest usability problem we had with Classroom Presenter
> 1.0 in the context of using it within venues was that it
> didn't inherit the existing venue context from the already
> running environment (in our case the venue that was already
> entered by our BarUI) and users rapidly got confused about
> how to cojoin presentations and a/v and other capabilities in
> the same venue. I imagine we'd repeat the experience with AG
> and I know you've done a lot of architecture work to overcome
> this usability limitation.
> As part of ConferenceApi, we have an easy way to tell CXP
> apps to join a dynamic venue (AKA a venue initialized on the
> client from an already known IP/Port, name, etc.), so if we
> could figure out a way for the AG 2.1 client to initialize
> the Conference Api with these values, then we could launch
> Classroom Presenter 'into' an AG 2.1 venue.
> The proposed method I would do this would be to use a command
> line utility that takes the IP/Port as parameters. That way
> you could invoke it via a Perl or TCL or whatever environment
> is best suited to you. We'd use the same IP, but slightly
> different ports (say Port+2 for RTP and Port+3 for RTCP)
> since there are some compatibility problems with our RTCP
> implementation and VIC's RTCP implementation that Colin
> pointed out but we haven't fixed yet and we're going to be
> using different parity error correction and encryption
> (Rijndael) for our RTP packet payloads.
> We can provide you the command line utilities and if you
> provide the invoke method, this should be an easy way to
> implement a user friendly story. We can either provide
> different command line utilities for "send" vs. "receive", or
> we could make these command line parameters.
> A side benefit of this is you could also invoke any other
> ConferenceXP capability the same fashion. For instance, we
> have a 3D shared model viewer under development, our A/V
> using Windows Media compression, and we're working on simple
> but high quality multicast app sharing over Rtp as well.
> My proposal would look like:
> ConferenceXPInvoke.exe IPAddress:Port CapabilityNameToSend
> ... CapabilityNameToSend
> For example:
> To start sending ClassroomPresenter and listen for incoming
> ConferenceXP
> streams:
> ConferenceXPInvoke 234.5.6.7:5004 ClassroomPresenter
> To start sending ClassroomPresenter plus Windows Media Video
> and listen for incoming streams: ConferenceXPInvoke
> 234.5.6.7:5004 ClassroomPresenter WMVideo
> To just listen for incoming streams:
> In each case, we'd listen/send Rtp on 234.5.6.7:5006 and Rtcp
> on 234.5.6.7:5007.
> If you want me to throw in a bonus, I could make sure that we
> punch a hole in the Windows XP firewall not only for UDP/5006
> & UDP/5007 but also UDP/5004 and UDP/5005. That way AG would
> get Windows XP Internet Connection Firewall support :-)
> We may also want parameters to turn on/off our AutoPlay
> behavior as well as window autoposition position behavior.
> I'm working on a sample command line app right now that
> implements custom window placement and this might be another
> area that you guys might be able to make AG/CXP integration
> friendlier, though it would take some thought as to how you
> would pass "only show windows here" information via the
> command line. Perhaps a rectangle bounding box of "only use
> this display space"?
> One aspect not covered in this proposal is passing user
> information to fill out the standard RTCP properties for a
> session, like CNAME, NAME, PHONE, LOCATION, etc. Right now
> we derive this information from a venue service lookup from
> email address that comes either from the Windows NT logon
> credentials or Passport credentials used with Windows
> Messenger. Perhaps as a v2 integration encore we could gather
> this contextual information from the AG session as well.
> Oh, and if you want to propose an AGInvoke.exe application
> that took IP/Port as parameters, I'm sure we could create a
> ConferenceXP Capability that launched that. That way we
> could start to get two-way compatibility working via a simple
> invoke workflow. This is something we discussed briefly at
> the last ConferenceXP Developers Conference, but neither of
> us found the spare time to follow up upon unfortunately.
> - jcb
> From: Ivan R. Judson [mailto:judson at mcs.anl.gov]
> Sent: Tuesday, August 19, 2003 7:35 PM
> To: Jay Beavers; 'Stuart Levy'; 'daagarwal'
> I have to chime in here, we've been looking at solutions and
> the german whiteboard software looks pretty cool; but
> Conference XP Presenter is even nicer. It's thought about the
> actual presenting problem in the context of collaboration,
> the german software combines the collaboration infrastructure
> (chat, presence, etc) into the same tool, which I find annoying :-)
> Just a thought.
> --Ivan
> > From: owner-ag-tech at mcs.anl.gov
> > [mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Jay Beavers
> > Sent: Tuesday, August 19, 2003 3:07 PM
> > To: Stuart Levy; daagarwal
> Slides on AG ?
> > ConferenceXP has a shared powerpoint/whiteboard tool called
> > "Classroom Presenter" that sends data over Rtp and is built
> > on top of the Tablet PC.
> > It also captures the ink using the Tablet PC SDK, so you get
> > high quality oversampled ink strokes with smoothing, colors,
> > widths, transparency and such. This application was written
> > by Richard Anderson and team from University of Washington on
> > top of the Conference Api and Rtp Api that is part of ConferenceXP.
> > See http://www.ConferenceXP.Net for details and download
> > links to binaries and source code.
> > - jcb
> > [mailto:owner-ag-tech at mcs.anl.gov] On Behalf > Of Stuart Levy
> > Sent: Tuesday, August 19, 2003 12:48 PM
> > To: daagarwal
> > Subject: Re: [AG-TECH] Sharing Handwritten Presentation
> Slides on AG ?
> > On Tue, Aug 19, 2003 at 12:25:57PM -0700, daagarwal wrote:
> > > Cindy,
> > > have yon considered having your instructor use a tablet
> PC for real
> > > time handwritten notes and equations? I am experimenting
> with one
> > > now. It seems good for on-the-fly handwritten equations and notes.
> > > Deb
> > Coolio. Some people here were thinking to try one. I'm
> > hoping to use the mbone whiteboard tool (wbd) with it --
> > though as someone here pointed out recently, wbd doesn't use
> > RTP, so I guess we can't use Voyager to record it, too bad.
> > Do you use that, or what?
> > Stuart
