[AG-TECH] AccessGrid 2.0 in Slackware 9.0
Stephen Bosch
sfbosch at netera.ca
Thu Aug 7 13:26:21 CDT 2003
I'm attempting to install the AccessGrid packages in Slackware 9.0.
First -- I'd like to point out the folly of providing the source
packages in RPM format only. That doesn't count as "source" -- that's a
source RPM. Sources should be in generic tar.gz packages.
Nevertheless, I have installed rpm in order to access the sources. I
have been attempting to build Slackware packages from the tar.gz files
extracted from the source RPMs, but things are not building; attempts to
rebuild the rpms using rpmbuild are also failing (some of the files
are "installed but not packaged" - I had a vague notion of converting
rpms to slackware packages but after this problem decided it would be a
better idea to just build from raw sources).
I'm perfectly happy building directly from source but the sources have
to build -- building vic fails with the following error:
rm -f video/grabber-qcam.o; c++ -o video/grabber-qcam.o -c -O2 -g -W -Wall
-Wno-implicit-int -Wno-return-type -DQCAMDEV -DLinux -DUSE_SHM -fsigned-char
-DED_YBITS=4 -DSIGRET=void -DNLAYER=8 -I. -Icodec/tmndec -Icodec/tmn-x
-Icodec/h263 -Irtp -Irender -Inet -Ivideo -Icodec -I../common
-I../tk-8.0/generic -I../tcl-8.0/generic -Icodec/jpeg -Icodec/p64 -I.
video/grabber-qcam.cpp
video/grabber-qcam.cpp:66: qcam.h: No such file or directory
video/grabber-qcam.cpp:69: qcam-os.h: No such file or directory
make: *** [video/grabber-qcam.o] Error 1
Obviously a missing header. What is the header from?
Is there a dependency chain posted anywhere on the AG 2.0 website?
-Stephen-
Stephen Bosch
Collaborative Systems Specialist
Netera Alliance Inc.
Biosciences 530B
2500 University Dr NW
Calgary AB T2N 1N4
tel (403) 220 2546
fax (403) 282 0838
