[AG-TECH] Question about Codec
    Lawrence A. Rowe
    Rowe at bmrc.berkeley.edu
    Wed Aug  6 18:50:44 CDT 2003
Hi -
if anyone is doing this, be sure to look at elan amir's dissertation
work.  sadly, i do not know of a pointer to an on-line version, but he
did write some papers.  and, OM has the code for his MegaGateway
(megagw) in it.  you are probably wondering what does it do?
well, you can configure the gateway to forward selected streams across a
bandwidth-limited link.  elan would run vic/vat at home using an ISDN
connection (symmetric 128Kbs) and he could select which streams would be
forwarded to his home and which would not.  the gateway also did
prioritization of the audio stream over the video streams, for obvious
reasons.
now you are probably thinking, that's great, can i run it.  and the
answer, as with nearly all OM projects done by students, is only if you
take the time to read/understand something about the code and the way
the apps work.  i don't recall their being documentation about the
gateway and apps, but there are some papers that elan published about
the models and algorithms.  here is the reference to the paper:
>   E. Amir, S. McCanne, R. H. Katz, "The Media Gateway Architecture: A
> Prototype for Active Services," ACM SIGCOMM'98
> Conference, Vancouver, Canada, (September 1998).
i'm sure you can find other reference by googling it.
	Larry
Professor Lawrence A. Rowe          Internet: Rowe at BMRC.Berkeley.EDU
Computer Science Division - EECS       Phone: 510-642-5117
University of California, Berkeley       Fax: 510-642-5615
Berkeley, CA 94720-1776            URL: http://bmrc.berkeley.edu/~larry
