[AG-TECH] Save configuration in Venue Client?
    Thomas D. Uram
    turam at mcs.anl.gov
    Wed Aug  6 17:33:34 CDT 2003
Randy:
That problem is a known bug.  The Node Management software won't create
new node configuration files.  It can, however, overwrite existing
files, so you should be able to save over a configuration already
there.  Also, you could create a file in that directory by hand, and
then overwrite it with the Node Management tool.
The configuration files are stored in the following directory:
Windows  =  C:\Documents and Settings\All Users\Application
Data\AccessGrid\nodeConfig
Linux  =  /usr/share/AccessGrid/nodeConfig
Tom
Randy Groves wrote:
> I'm having a problem saving my configuration in the Venue Client.
> This is on Windows XP.  The error I'm seeing is:
> 08/06/03 14:30:38 ERROR Exception in AGNodeService.StoreConfiguration.
> Traceback (most recent call last):
>   File "D:\Python22\Lib\site-packages\AccessGrid\AGNodeService.py",
> line 468, in StoreConfiguration
>     raise Exception("Can't write config file %s" % (file))
> Exception: Can't write config file E:\Documents and Settings\All
> Users\Application Data\AccessGrid\nodeConfig\NewConfig
> So - I'm in the Administrator's group, and Administrators have full
> control, but the directory and all of its contents are marked
> 'Read-only' and try as I might, I can't change that (or I change it
> and it goes right back)
> Am I doing something wrong here?
> -randy
