[AG-TECH] AG2.0 and linux
Thomas Uram
turam at mcs.anl.gov
Thu Apr 24 10:41:11 CDT 2003
If you want to run a venue server, you can execute VenueServer.py. By
default, it will run on hostname:8000. To access this server from
outside your firewall, you need to open ports 8000, 8002, 8004, and
8006. The venue server will create a single venue at startup. The
venue server can be configured using VenueManagement.py, pointed at the
server url (https://hostname:8000/VenueServer).
We are working on user guide materials now, so a better reference is on
its way.
Tom
Randy Heiland wrote:
>>This problem is a version mismatch between the venue server and venue
>>client. The venue client code you have is expecting clients and
>>services in the venue state, but the server to which you are connecting
>>(presumably vv2:9000) is running beta3 code which does not include
>>these in the venue state. If you run a client and server from the same
>>version of the code (both from beta3, say), they would be using the same
>>definition of venue state, and this problem wouldn't occur. You could
>>do the same using cvs code, but then there are fewer guarantees.
>Relate to this... is there a doc explaining how one starts up a venue server?
> I assume it involves the VenueServer and VenueServerRegistry classes (duh),
>but other than that I'm lost.
>thanks,
>Randy
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20030424/ef6f8a2b/attachment.htm>
