[AG-TECH] AG2.0 and linux
Randy Heiland
heiland at ncsa.uiuc.edu
Thu Apr 24 09:46:26 CDT 2003
> This problem is a version mismatch between the venue server and venue
> client. The venue client code you have is expecting clients and
> services in the venue state, but the server to which you are connecting
> (presumably vv2:9000) is running beta3 code which does not include
> these in the venue state. If you run a client and server from the same
> version of the code (both from beta3, say), they would be using the same
> definition of venue state, and this problem wouldn't occur. You could
> do the same using cvs code, but then there are fewer guarantees.
Relate to this... is there a doc explaining how one starts up a venue server?
I assume it involves the VenueServer and VenueServerRegistry classes (duh),
but other than that I'm lost.
thanks,
Randy
