[AG-TECH] PIG Specifications
    Jonas Talandis
    jonast at evl.uic.edu
    Thu Apr 17 11:41:22 CDT 2003
Burn-in is a potential problem with any plasma. It's best to avoid static
images and vary your window positions. The newer displays use some pixel
orbiting and screen saver techniques to help deal but not eliminate the
issue. I've also heard that plasmas have a half-life of sorts, that the
image degrades over time, though haven't experienced that.
At 11:13 AM 4/17/03, Brian Corrie wrote:
>Hello all,
>One word of caution with respect to Plasmas. Beware the "burn in" effect if
>you use the Plasma in 4:3 non-stretched mode. If you run a plasma in that
>fashion, the plasma will not be used on the left and right edges and
>eventually will lead to discontinuities in color in those areas. If you then
>got to 16:9 and use that protion of the screen, you will notice differences
>in the color and will still be able to see a ghost of the area of the screen
>that was unused in non-stretched mode...
>Cheers,
>Brian
>         -----Original Message-----
>         From: Todd Needham [mailto:toddn at microsoft.com]
>         Sent: Thu 4/17/2003 8:21 AM
>         To: Nolan, Kevin [NCSUS]; Jay Beavers; Jonas Talandis; Frank
>Sweetser; Maat, Steve
>         Cc: AG-Tech (E-mail)
>         Subject: RE: [AG-TECH] PIG Specifications
>         On the other hand, you can get a pair of 20â LCD displays
> capable of
>1600x1200 each for $2500 (in case you decided to go high res for some
>reason).
>   _____
>         From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
>Behalf Of Nolan, Kevin [NCSUS]
>         Sent: Thursday, April 17, 2003 5:13 AM
>         To: Jay Beavers; Jonas Talandis; Frank Sweetser; Maat, Steve
>         Jay -
>         We have two type's of plasma brands in our lab -
>         1)  The Sony 42inch Plasma - which is costly once you start adding
>the option cards
>         2)  We have been using the NEC Plasma Syncs - they come in many
>versions and we have the PlasmaSync - 42MP1 and 50MP1.  These work great with
>native and HD sources.  You could have 2 640X480 pictures no problem.
>         Kevin
>         From: Jay Beavers [mailto:jbeavers at microsoft.com]
>         Sent: Wednesday, April 16, 2003 11:57 PM
>         To: Jonas Talandis; Frank Sweetser; Maat, Steve
>         We have the need of a plasma screen for a "back wall display" in one
>of our nodes.  Does anyone have a recommended brand & model?
>         We only need it to display a single site's video, so it doesn't have
>to have high resolution, but it needs to be large enough to allow reasonable
>viewing from about 20' away (image stretched to maximum 4x3
>         size) and bright enough to be seen in a room in which lighting is
>high to support good image capture of the entire audience.
>         Would you recommend a different model if I wanted to display 2 or 3
>640x480 native resolution streams?
>Behalf Of Jonas Talandis
>         Sent: Wednesday, April 16, 2003 2:53 PM
>         To: Frank Sweetser; Maat, Steve
>         I embrace the use of plasma screens. We have used them in several
>nodes,
>         the image quality is superb and you have the option of adding an
>         interactive whiteboard, without the noise and overhead mounting of
>         projectors. If the aspect ratio bothers you can use the 4:3 mode or
>spec a
>         smaller display. The limiting factor is the image size needs to be
>         appropriate to the size of the room. The viewers need to be within
>8-10 feet.
>         At 03:43 PM 4/16/2003, Frank Sweetser wrote:
>         >On Wed, Apr 16, 2003 at 04:33:09PM -0400, Maat, Steve wrote:
>         > > Is a Plasma screen appropriate or would a projector be better?
>         >Personally I'd try and avoid plasma screen, unless you can convince
>         your
>         >video display to do the right aspect ratio.  Standard video
>resolutions
>         on a
>         >16:9 ratio plasma end up looking way too stretched out.
>         >Frank Sweetser fs at wpi.edu
>         >WPI Network Engineer
