[AG-TECH] VTC on PIG
Randy Groves
randy.groves at boeing.com
Fri Apr 4 09:41:14 CST 2003
Yes you can use VTC on a PIG, but it requires some modifications. I did
this a bit ago, and until you mentioned it in this note, I'd
forgotten. There are problems with what the bridge returns, and what I
ended up doing is creating a special version of vtc for mash. I'll look
back at my machine and see if the changes are portable. I may just be able
to send out the modified vtc with instructions.
-randy
At 02:44 PM 4/2/2003 -0500, Jennifer Teig von Hoffman wrote:
>My understanding (perhaps limited) is that one cannot use VTC on a PIG.
>You may want to look into whether QuickBridges could be made available for
>the sessions you will participate in, since QuickBridge and PIG play
>together quite nicely.
>- Jennifer
>Gheni Abla wrote:
>>Hi,
>>I am trying to setup a PIG. While our network people are working on
>>multicast and firewall issues, I wanted to feed my PIG with unicast
>>connection using multisession bridge.
>>I registered it and got bridge access approved. I downloaded, installed
>>vtc into C:\ag\agapps\bin and added this directory to the path variable.
>>Then I started virtual venues, entered JackFrostRoom and saw following
>>bridge assignments:
>>audio: vtc JackFrostRoom_audio bridge-2.accessgrid.org audio display: vtc
>>JackFrostRoom_video bridge-2.accessgrid.org display video: vtc
>>JackFrostRoom_video bridge-2.accessgrid.org video
>>Then, I executed the following command: C:\ag\agapps\bin>vtc
>>JackFrostRoom_audio bridge-2.accessgrid.org audio connected to bridge at
>>140.221.8.206
>>vtconnect meeting_name bridge_address password
>>But, it didn't start an instance of rat. Other vtc commands for display
>>and video generated same message, but didn't start anything.
>>What is wrong with my PIG?
>>Thanks.
>>--Gheni
