[AG-TECH] AG Grid dream system
Ivan R. Judson
judson at mcs.anl.gov
Fri Sep 27 14:45:45 CDT 2002
Ok, shameless plug.
Monday we'll start our 3 talks on 2.0, which will address this issue
from both sides (high and low end systems).
--Ivan
Ivan R. Judson .~. http://www.mcs.anl.gov/~judson
Futures Laboratory .~. 630 252 0920
Argonne National Laboratory .~. 630 252 6424 Fax
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov
> [mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Brian Corrie
> Sent: Friday, September 27, 2002 2:31 PM
> To: ag-tech at accessgrid.org
> Subject: RE: [AG-TECH] AG Grid dream system
> Hi Don,
> > It's interesting to hear all the comments about AG
> enhancements. At
> > the same time, I would humbly suggest that "the other end" is very
> > important, too. Given that most of the Earth's population
> has minimal
> > to no network bandwidth, what kinds of things can we do to make an
> > AG-like environment available to those who have been "left out?" I
> > think it's interesting that much of this could be attacked
> by asking
> > the question, "what kinds of things can we do to make an AG-like
> > environment available at home?" Clearly, bandwidth is the limiting
> > factor - can we find ways to work with these constraints,
> and can we
> > do so in a way that somehow integrates with the high-level features
> > suggested in previous messages?
> I agree, and I think this is where the casual interaction
> within an AG will happen. If you look at the CSCW research,
> casual interaction is fundamental to how we communicate and
> work. You can't have casual interaction if you have to go to
> a physical AG room to participate. If you want the AG to be a
> communication medium that supports such an interaction style
> then you have to be able to support the lower end
> technologies. In some ways this moves away from the original
> AG concept of multi-camera, multi-display systems but I think
> this is an increasingly important area to consider...
> Oddly enough, we were testing out the QuickBridge the other
> day (works great by the way) and I fired up a test from home.
> I was only receiving video (not
> sending) and I certainly can't claim to have done extensive
> tests, but the video streams that I was receiving (only a
> couple of course) worked fine. This is a very interesting
> area to explore!!!
> Cheers,
> Brian
