[AG-TECH] Vic thoughts
Michael Gates
mgates at sdsc.edu
Tue Sep 3 16:33:51 CDT 2002
MessageWe were having a similar problem with our display machine (not even
PIG). We discovered that we only experienced this problem on a single CPU
machine. As soon as we setup on a dual CPU, the problem went away. The
single CPU was a P4 1.8GHz, and the first duals we setup without the problem
were P3 600Mhz. Maybe the code is geared for dual CPUs?
hope it helps,
-Mike
Michael Gates
Information Technology
Support and User Services
mgates at sdsc.edu
858.534.8369
mgates at pager.sdsc.edu
Room 265
-----Original Message-----
From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov]On
Behalf Of Heisen, Andrew [NCSUS]
Sent: Tuesday, September 03, 2002 10:59 AM
To: Nolan, Kevin [NCSUS]; 'ag-tech at mcs.anl.gov'
Subject: RE: [AG-TECH] Vic thoughts
To clarify the below, our problem seems to be a CPU utilization one. With
only a few windows open, or even just one with substantial motion in the
video stream, the CPU time required by OM Vic skyrockets to 100%,
effectively disabling the machine. In contrast, the v2.8nlsde-2.1.3-1114v
version of vic utilizes the CPU much more efficiently. Any suggestions on
how to improve this would be appreciated. I should note that the settings
we are using are h261 compression at 29fps and quality of 1, in case that
affects things.
Thanks.
From: Nolan, Kevin [NCSUS] [mailto:knolan at NCSUS.JNJ.COM]
Sent: Tuesday, September 03, 2002 8:13 AM
To: 'ag-tech at mcs.anl.gov'
Subject: [AG-TECH] Vic thoughts
We have been doing a lot of work lately with the various versions of the
PIG - vic.exe on Windows 2000/XP. We have found that when opening more then
4 windows the only version that seems capable of performing exceptionally
well is the v2.8nlsde-2.1.3.-1114 version of vic. If we use the Open Mash
or the vic.exe (DD or without) off the AG site - the applications run but
seem to hang or skip on a computer when opening more then 4 windows at once.
Has anyone experienced this? If so, do you have a work around? We are
using the NVIDIA Quadro4 Video cards with 128MB of Video Memory.
thanks -
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20020903/f843f8cc/attachment-0001.htm>
