[AG-TECH] Vic thoughts
Heisen, Andrew [NCSUS]
AHeisen at NCSUS.JNJ.COM
Tue Sep 3 12:59:29 CDT 2002
To clarify the below, our problem seems to be a CPU utilization one. With
only a few windows open, or even just one with substantial motion in the
video stream, the CPU time required by OM Vic skyrockets to 100%,
effectively disabling the machine. In contrast, the v2.8nlsde-2.1.3-1114v
version of vic utilizes the CPU much more efficiently. Any suggestions on
how to improve this would be appreciated. I should note that the settings
we are using are h261 compression at 29fps and quality of 1, in case that
affects things.
Thanks.
-----Original Message-----
From: Nolan, Kevin [NCSUS] [mailto:knolan at NCSUS.JNJ.COM]
Sent: Tuesday, September 03, 2002 8:13 AM
To: 'ag-tech at mcs.anl.gov'
Subject: [AG-TECH] Vic thoughts
We have been doing a lot of work lately with the various versions of the PIG
- vic.exe on Windows 2000/XP. We have found that when opening more then 4
windows the only version that seems capable of performing exceptionally well
is the v2.8nlsde-2.1.3.-1114 version of vic. If we use the Open Mash or the
vic.exe (DD or without) off the AG site - the applications run but seem to
hang or skip on a computer when opening more then 4 windows at once. Has
anyone experienced this? If so, do you have a work around? We are using
the NVIDIA Quadro4 Video cards with 128MB of Video Memory.
thanks -
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20020903/cf0c5b9f/attachment.htm>
