[AG-TECH] Solving PAL <> NTSC with VIC
Bart Kerver
Bart.Kerver at surfnet.nl
Fri Sep 6 07:55:05 CDT 2002
Justin
> There should be a file 'video-config' somewhere in /usr/local/ag. It's an
> XML description of the configuration for the various video feeds. In
> there is where 'NTSC' is specified, and it *should* be as easy as changing
> 'NTSC' to 'PAL'.
What version of the software are you using?
There is no such parameter in the /lib/video-config file.
If you look at the DTD (/usr/local/ag/apps/vrm/config.dtd) that belongs
to this XML file, a setting for NTSC/PAL is no part of it.
Even adding this by hand doesn't work.
Any other clues?
Bart
