[AG-TECH] Rtpmon Problem
    Michael Daw
    mike.daw at man.ac.uk
    Tue Oct 29 09:29:20 CST 2002
Well, I was trying with tk8.3/tcl8.3, which isn't so far from UCL's 8.0.3.
After furiously hacking at the configure script, I got the following C++
compilation errors, which made me give up...
[root at george rtpmon-1.0a7]# make rtpmon
c++ -o
main.o -c -I/usr/X11R6/include -I/usr/include -g -O -DHAVE_STDARG_H=1 -DHAVE
_SYS_BITYPES_H=1 -DHAVE_SYS_SELECT_H=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_VARARGS_H
=1 -DHAVE_SNPRINTF=1  main.cc
main.cc: In function `void usage ()':
main.cc:57: `exit' undeclared (first use this function)
main.cc:57: (Each undeclared identifier is reported only once for each
function it appears in.)
main.cc: In method `int HaveFontCommand::command (int, const char
*const *)':
main.cc:82: `Tk_GetFontStruct' undeclared (first use this function)
main.cc: In function `const char *disparg (int, const char **, const
char *)':
main.cc:109: `getopt' undeclared (first use this function)
main.cc: In function `int main (int, const char **)':
main.cc:159: `close' undeclared (first use this function)
make: *** [main.o] Error 1
> -----Original Message-----
> From: Bob Olson [mailto:olson at mcs.anl.gov]
> Sent: 29 October 2002 15:12
> To: Michael Daw
> Cc: AG Technical Developers
> Subject: RE: [AG-TECH] Rtpmon Problem
> > I had to do a number of frigs to run ./configure "successfully" (because
> > this expected tcl no later than 7.6). After that, make gave me lots of
> > errors - that's when I gave up.
> Ah - try it with the tcl/tk that UCL distributes. I've always had good
> luck with that.
> --bob
