[AG-TECH] event server seg fault
Brian Corrie
brian.corrie at newmic.com
Sat Oct 19 13:15:56 CDT 2002
Hello all,
We made the change as well and it seemed to fix the problem! Thanks Jeff!
Cheers,
Brian
-----Original Message-----
Sent: Fri 10/18/2002 7:05 PM
To: Jeff Long
Cc: ag-tech at mcs.anl.gov
Subject: Re: [AG-TECH] event server seg fault
To Brian and Jeff (and interested others)--
I just replaced the jre1.2.2 in /usr/local/ag with jre-1.2.2_0.1.3
from the java website Jeff gave me. And now everything works again!
So many thanks for the suggestions... I switched betw. venues and
nothing crashed!
-- marcia
Jeff Long wrote:
> I think Brian is on the right track as I noticed similar problems
> (arm/vrm-eventlistener crashes when changing rooms) after the last
glibc
> update. I believe I've solved my problem by replacing
> /usr/local/ag/jre-1.2.2 (keep a copy!) with jre 1.2.2_013 from
> http://java.sun.com/products/jdk/1.2/download.html.
> Jeff Long
> Brian Corrie wrote:
> > Marcia,
> > We recently saw something like this after upgrading some of the
RH software.
> > We think it was an upgrade to the glibc libraries that caused the
problem -
> > not sure if we have solved it or not... Did you upgrade your
system lately???
> > Brian
> >>From: Marcia Perry [mailto:mperry at lbl.gov]
> >>Sent: Thursday, October 17, 2002 2:04 PM
> >>To: ag-tech at mcs.anl.gov
> >>Subject: [AG-TECH] event server seg fault
> >>Hi,
> >>Both arm-eventlistener and vrm-eventlistener are seg faulting
> >>w/ error msg like:
> >> vrm-eventlistener: line 21: 30166 Seg Fault \
> >> $JAVA ag.VideoResourceManager --eventURL \
> >> $EVENT_SERVER_URL --cacheURL $CACHE_URL $*
> >>I tried killing everything and restarting all the ag s/w
> >>with no luck. Can anyone please advise?
> >>Thanks,
> >>-- marcia
> >>Marcia Perry MPerry at lbl.gov
> >>Lawrence Berkeley National Laboratory WORK# (510) 486-6786
> >>1 Cyclotron Road FAX# (510) 486-6363
> >>Berkeley, CA 94720 MS: 50A-3111
