[AG-TECH] Audio Question
Osland, CD (Chris)
C.D.Osland at rl.ac.uk
Tue Oct 15 04:15:27 CDT 2002
Naturally many things can cause crackling and pops, but IMHO
by far the most common is not getting the levels right through
the whole audio chain. With a Gentner AP800 there are the
following variable gain points (from memory - I may have missed
one out!):
mic gain - coarse and fine together - aim for post-gain level
that only exceeds 0 dB occasionally and by no more than
say 6 dB
output channel gain - ditto
RAT 'send' gain - normally I aim for 70% - 80%, into the
yellow but not the red
If any of these are higher or lower and then compensated for
by another gain, the chances of cracking, popping, distorting
and general nastiness are high. Always get these right before
attacking any other parameters; e.g. using a limiter to correct
too high a post-gain mic level adds a second possible form of
distortion - it doesn't remove the first!
In these days of all (or at least most) signal processing being
in the digital domain, errors are punished much harder than
in analogue days.
Cheers
Chris
____________________________________________________________________
Chris Osland Office tel: +44
(0) 1235 446565
Digital Media and Access Grid Medialab tel: +44 (0)
1235 446459
BIT Department Access Grid room tel: +44
(0) 1235 445666
e-mail: C.D.Osland at rl.ac.uk Fax: +44
(0) 1235 445597
CLRC Rutherford Appleton Laboratory (Bldg. R18)
Chilton, DIDCOT, Oxon OX11 0QX, UK
[The contents of this email are confidential and are for the use of the
intended recipient only.
If you are not the intended recipient do not take any action on it or show
it to anyone else,
but return this email to the sender and delete your copy of it.]
-----Original Message-----
From: Nolan, Kevin [NCSUS] [mailto:knolan at ncsus.jnj.com]
Sent: 14 October 2002 16:48
To: 'Robert Olson'; Nolan, Kevin [NCSUS]; 'ag-tech at mcs.anl.gov'
Subject: RE: [AG-TECH] Audio Question
We are at 16khz - it could be that we are too hot - just thinking of other
options. thanks
From: Robert Olson [ mailto:olson at mcs.anl.gov <mailto:olson at mcs.anl.gov> ]
Sent: Monday, October 14, 2002 11:04 AM
To: Nolan, Kevin [NCSUS]; 'ag-tech at mcs.anl.gov'
Subject: Re: [AG-TECH] Audio Question
You're not at 8khz, are you? the audiopci cards at 8khz can introduce
distortion.
have you carefully balanced mic & system levels? perhaps you are
overdriving a level at some point in the audio chain. Hard to tell for sure
what it is without hearing it.
--bob
At 10:39 AM 10/14/2002 -0400, Nolan, Kevin [NCSUS] wrote:
>At Johnson & Johnson, we are having some audio issues with slight
>crackling as we communicate with other sites. Has anyone seen this in the
>past? These are room to room systems.
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20021015/13635c44/attachment-0001.htm>
