[AG-TECH] Response to AG Retreat Day 1
Lawrence A. Rowe
Rowe at bmrc.berkeley.edu
Tue Oct 1 12:19:33 CDT 2002
Luc Renambot wrote:
> Plenty of nice ideas from Allan... To continue on the stream
> subject, I would really like to see VIC and RAT put in pieces,
> putting a RTP stack in the center of an AccessGrid SDK. I should
> be able to discover and register to data streams coming from
> a specific venue: for instance I send that video stream to a
> trans-coding service for unicast transmission to PDAs (EVL Continuum)
> or this high-resolution MJPEG stream for hardware decoding (RTPtv),
> or this group of streams for regular display, and so on. It would allow
> things like "I don't display anything coming from ANL" or "I group
> together all the active videos" ("active" should be defined at will)
> or "I bridge all the audio streams coming from 130.xxx.xxx.xxx".
> Also if I discover a 3D stream in the venue, I start a 3D viewer....
> Luc
> renambot at cs.vu.nl
those are good ideas. we were/are working on software to support this
sort of thing outside the context of the AG technology, but with the
intent of using it in our AG control research. i've included a paper
that describes the technology and ideas we have been working on -- a
system called indiva. the system supports abstractions/commands for
manipulating mbone conferences (i.e., sessions and streams), streaming
media services (e.g., encoders and decoders), and a/v equipment (e.g.,
cameras, routing switchers, etc.).
there is an early prototype of the system available for you to play with
- check out http://bmrc.berkeley.edu/projects/indiva. this is early,
buggy software, but you might find it an interesting system to play
with.
A paper describing the system is available at
http://www.openmash.org/resources/pubs/2002/166/
comments welcomed...
Larry
Professor Lawrence A. Rowe Internet: Rowe at BMRC.Berkeley.EDU
Computer Science Division - EECS Phone: 510-642-5117
University of California, Berkeley Fax: 510-642-5615
Berkeley, CA 94720-1776 URL: http://bmrc.berkeley.edu/~larry
