[AG-TECH] inverted AG cameras?
Russ Wolf
russ at bu.edu
Tue Oct 1 09:55:11 CDT 2002
I know with the older D-31 camera sony sold two different models, one
for mounting with the base up and one with the base down.
I'm not sure if the same exists for the newer D-100 but the D-31
upsidedown mount had a much greater tilt so that you could look straight
down almost (wheras you can't look straight up with the base-on-bottom
model)
-Russ
On Mon, 2002-09-30 at 13:42, Jason Hale wrote:
> All,
> We are installing A/V equipment in our under-construction AG node. The
> vendor who is installing the cameras wants to ceiling- mount them for
> aesthetics, but it seems that, with this particular camera model, that
> means the camera would be upside down. Is their anything in the AG software
> that would allow for inverting the picture so that something like this
> would work, or should we stick to wall mounts?
> The cameras are Sony EVI D-100 NTSC. The video cards are Hauppage Model
> #404 WinTV/PCI.
> Thanks,
> - Jason Hale
> University of Mississippi
> jghale at olemiss.edu
