[AG-TECH] Multi-Headed Display
Allan Spale
aspale at evl.uic.edu
Fri Oct 18 10:47:40 CDT 2002
Luc,
Thanks for the plug. EVL is working on creating a large tiled display.
If anyone is in need of technical details building one of these displays,
please let me know, and I will try to send the mail to the right person so
that you can receive the answer that you are looking for.
Allan
EVL at UIC
node-op
On Fri, 18 Oct 2002, Luc Renambot wrote:
> For demo purpose, EVL built a 4-tile display
> with 4 18" TFT at 1280x1024. Looks pretty nice.
> Just remove the plastic frame around each panel, and fix
> them together...
> Luc.
> renambot at cs.vu.nl
> ] -----Original Message-----
> ] From: owner-ag-tech at mcs.anl.gov
> ] [mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Osland, CD (Chris)
> ] Sent: Friday, October 18, 2002 11:39
> ] To: 'Don Morton'; Justin Binns; Mike Weaver - MICS/USDOE
> ] Cc: Sergeant A. G. Tech
> ] Subject: RE: [AG-TECH] Multi-Headed Display
> ] Don,
> ] $5000 ??? The monitors are only GBP200 = USD300 each -
> ] that's a lot of glue you'll be using! For $5000 you could
> ] probably do a 2x4 array of monitors - 4096 x 1536 = 6
> ] Mpixels, rather than 1x3 which gives you 2.25 Mpixels (and
> ] still have money left over for the second G200 card). [Does
> ] the Matrox software actually handle 8-9 channels?]
> ] I have 3 industrial LCD modules at home (1 inch steel
> ] surround) - I'll see what they look like hooked up to our node.
> ] Cheers
> ] Chris
