[AG-TECH] Sound localisation work?
Osland, CD (Chris)
C.D.Osland at rl.ac.uk
Thu Nov 28 07:32:14 CST 2002
It was a subject I attacked during a short sabbatical in Germany
a few years ago for a thing called the Communication Wall - a VR
+ video keying approach to the same sort of problem as the AG
aims to tackle.
One of the problems that dogged that project was that as they were
using hard surfaces for the rooms (they used rear-projected stereo
projectors) there was a disastrous amount of secondary reflections
of any sound source. I draped carpet over the side walls (not used
for projection, but they happened to be plasterboard and so hard)
and improved things a lot.
There are many problems to solve in the AG context:
1. non-unique views of participants:
If a person is visible in more than one view, where should the
virtual sound source corresponding to that person be positioned?
2. multiple people viewing/hearing at each site
There is basically no known solution to the problem of how to
create a sound field that is the same for several people, unless
you put headphones on each person AND headtrack them. The problem
can be partially solved by using phase differences more than
amplitude differences (this is done by the TiMax system used in
theatres) but the normal layout of an AG node makes this difficult
to achieve - the physical distances are too small.
3. the rooms have to be excellent acoustically before you start
This is really the same point as I made above concerning reflective
walls - if there are uncontrolled reflections, any effort put
into generating localized sound is wasted.
I created a website about my project and will try to get that
up somewhere - I think it's fallen off the edge of our web
for the present.
I'll try to find references to things like
TiMax - the theatre system - they were at
Robin Whittaker
Out Board Electronics Ltd
www.outboard.co.uk
T: +44 (0)1223 837827
F: +44 (0)1223 837798
but went into receivership some months ago;
I think Robin has hooked up with another firm
to try to keep TiMax going
Crystal River - people who make sound localization cards for PCs
and the places where I found out stuff for my sabbatical. It looks
as though Crystal River have gone belly up as well.
A couple of useful links are
http://www.dform.com/inquiry/spataudio.html
and http://www.anu.edu.au/ITA/ACAT/Ambisonic/Spatiallinks.html
Enjoy
Chris
____________________________________________________________________
Chris Osland Office tel: +44
(0) 1235 446565
Digital Media and Access Grid Medialab tel: +44 (0)
1235 446459
BIT Department Access Grid room tel: +44
(0) 1235 445666
e-mail: C.D.Osland at rl.ac.uk Fax: +44
(0) 1235 445597
CLRC Rutherford Appleton Laboratory (Bldg. R18)
Chilton, DIDCOT, Oxon OX11 0QX, UK
[The contents of this email are confidential and are for the use of the
intended recipient only.
If you are not the intended recipient do not take any action on it or show
it to anyone else,
but return this email to the sender and delete your copy of it.]
-----Original Message-----
Sent: 28 November 2002 12:52
To: AG Technical Developers
Subject: [AG-TECH] Sound localisation work?
I'm just wondering if anyone knows of any work going on to do with sound
localisation in the AG? I'm thinking particularly of development to help
locate where peoples' images are on the screen and in holding simultaneous
conversations between sites, or anything related.
I'd be grateful if someone could provide contacts (if any).
--Mike
Michael Daw
SVE Group (Supercomputing, Visualization and e-Science)
Manchester Computing, Kilburn Building,
University of Manchester, Manchester M13 9PL, UK
Tel: +44 (0)161 275 7026
Fax: +44 (0)161 275 6800
Email: michael.daw at man.ac.uk
http://www.sve.man.ac.uk/General/Staff/daw
