[AG-TECH] ddvic error
    Brian Corrie
    brian.corrie at newmic.com
    Wed Nov  6 12:54:43 CST 2002
Hello all,
We have seen this error as well in the Test Room. I seem to remember the
mention of a problem with vic dying when someone in the venue changes video
settings. If someone is in the room and tweaking the video this could be
causing the problem. I have noticed with the PIG software that the settings
for vic do not always work and we have to go in and configure before
transmitting. If someone with a PIG node does a transmit and then tweaks the
settings this may be the answer.
No investigation on this done on our part, just rumour and some thoughts at
this point...
Cheers,
	Brian
> -----Original Message-----
> From: Darin Oman [mailto:darin at ucar.edu]
> Sent: Wednesday, November 06, 2002 10:13 AM
> To: Robert Olson
> Cc: ag-tech at mcs.anl.gov
> Subject: Re: [AG-TECH] ddvic error
> Not sure. I'll pay closer attention next time it happens.
> The node op at NCSA got the error at the same time I did.
> Darin
> Robert Olson wrote:
> > Hmmmm. Someone here mentioned that error as well.
> > Does it look like an error message that came from ddvic itself?
> > At 10:58 AM 11/6/2002 -0700, Darin Oman wrote:
> >> Yes! I've had that error a few times over the last few
> days. It would
> >> mostly happen when I moved from the lobby to the test
> room. I thought
> >> it was a local problem (I deleted ag/agapps/bin directory and
> >> reinstalled display software and have had the error only
> once since)
> >> but now I'm not so sure. Is something on the network causing the
> >> error? Is there a bug in the software (I'm running AG
> 1.2)? I, too,
> >> would like to get this figured out.
> >> Darin Oman
> >> NCAR
> >> Rabarison Monika Klara wrote:
> >>> Hello,
> >>> Have anybody met the same problem as I have now in the lobby?
> >>> Error on the display machine: "ddvic error, you need to restart
> >>> the program..". I went to JSU venue and everything is fine.
> >>> Any hint?
> >>> Monika
> >>> Monika Rabarison
> >>> System Administrator
> >>> HPVCI
> >>> Jackson State University
> >>> Office:(601)979-5933
> >>> SciVis Lab:(601)979-1061
> >>> jsuVisNode:(601)979-1056
