[AG-TECH] Video cam advice for XP/linux laptop
Christoph Willing
chris at vislab.usyd.edu.au
Tue Nov 12 17:03:44 CST 2002
On Wed, 2002-11-13 at 02:52, Michael Daw wrote:
> Dear all,
> I'm about to configure a laptop to be a PIG-like machine and I need to buy a
> camera. I'm going to make the laptop dual boot WinXP and Linux.
> I liked the look of those Kritter cams, but it seems they don't work under
> Linux
> (http://www-unix.mcs.anl.gov/web-mail-archive/lists/ag-tech/2002/06/msg00125
> .html). Has anyone got any recommendation for a similar thing that has good
> quality video and works under both OS's? The e-mail at the link above lists
> quite a few cameras, but I'd be interested in personal
> recommendations/advice on models.
> --Mike
Mike,
I've been trying out a Logitech Quickcam Pro 4000 via usb on our single
machine node under Linux. It uses the pwc philips module and requires a
pre-install of usb-uhci module. For full picture size (640x480) you'll
also need to post-install the pwcx-i386 module (separately supplied, as
described in above email).
It comes with installation CDs for Windows so I guess it works that way,
but I haven't tried it.
Its downsides for me are
1. doesn't work with "normal" vic. It _does_ work with openMash vic
(which I quite like for other reasons) however openMash vic uses a lot
of cpu whenever there are active video streams i.e. you've clicked on a
thumbnail to open that streams window
2. the size of 640x480; when that is halved to fit into a H261 frame it
leaves a fairly wide border around the image i.e. 320x240 image in
352x288 window
3. I can't achieve frame rate better than 10fps under openMash vic. UCL
vic achieves 30fps but no picture.
Maybe someone is interested in fixing either of the vic programs?
chris
Chris Willing Telephone (61-2) 9351 3005
VisLab, A28 Facsimile (61-2) 9351 1880
University of Sydney
NSW 2006 Australia http://www.vislab.usyd.edu.au
