[AG-TECH] RTP CNAMEs from AG nodes
Robert Olson
olson at mcs.anl.gov
Wed May 29 07:09:47 CDT 2002
At 11:23 AM 5/29/2002 +0100, S.Booth wrote:
>I was wondering if it would make sense to modify vic,rat,etc so that all
>RTP streams from an AG node use the same CNAME attribute
It might indeed make sense to do that - it's something I've thought about
doing but haven't gotten around to.
>At the moment CNAMEs are constructed as <username>@<ip-address>
>so audio and video streams have different CNAMEs on a standard AG node
>but my uderstanding of
>RFC-1889 is that CNAMEs are intended to associate streams from the same
>participant for purposes like lip-sync and audio switching.
There are a lot of SHOULD's in the section defining CNAME as user at host,
which means with good reason the recommendations there can be changed. I
think this situation definitely qualifies.
(Latest RTP draft at
http://www.ietf.org/internet-drafts/draft-ietf-avt-rtp-new-11.txt)
>I know that AG does not need audio switching but this would make it easier
>to interface with other systems.
For instance, I suspect that VRVS in H323-bridging mode may get confused
with the audio/video separation (it does video-follows-voice switching).
>Even in an AG context it would be nice to be able to get audio switching
>to work because we could re-use the mechanism to highlight the windows
>from the speakers node as this would make it easier to locate people
>in sessions with a large number of sites taking part.
Agreed.
I suspect I'll roll this into the new venue server/ node software work.
--bob
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20020529/f3264433/attachment-0001.htm>
