[AG-TECH] vic gui freezes...
    ag.zam
    ag.zam at fz-juelich.de
    Tue May  7 04:06:36 CDT 2002
Hello again,
24 frames seem to solve our problem, thanks to Christoph for the hint.
But how do we set up our vic defaults so that it starts with 24 fps ?
Martin
Christoph Willing wrote:
> Martin,
> We have seen similar problems here when running at 25fps (using
> a Slackware 8.0 Linux). We therefore run our vic's at 24fps and
> all is OK. The difference between 24 & 25 is minimal.
> Because we've never used a real ANL release, I'm not sure what their
> default frame rate is set to - is it 30fps (expecting NTSC cameras)?
> For PAL cameras it should be 25 fps but, as I said, 24 fps works well
> and doesn't freeze the gui.
> chris
> >Hello everybody,
> >we are trying to fix a problem, that we are facing since the very
> >beginning of our AG activity, and that stayed with us throughout various
> >changes in AG software and OS releases:
> >whenever we start several vic instances on our capture machine with the
> >AG default frame rate / bandwidth values, the gui freezes after some
> >seconds. Video transmission is ok, but we have no chance to change the
> >settings of a specific video stream unless we restart the vic.
> >The problem disappears when we start with the low transmission/frame
> >rates of the ucl-vic defaults.
> [snip]
> >We are currently running SuSE. 7.3 on a dual Pentium III 866 MHz, but we
> >observed the same problems under the AG RedHat Release.
> >Any help would be greatly appreciated.
> >Martin
> __
> Chris Willing                      Telephone   (61-2) 9351 3005
> VisLab, A28                        Facsimile   (61-2) 9351 1880
> University of Sydney
> NSW 2006 Australia                http://www.vislab.usyd.edu.au
