[AG-TECH] Display computer for JSUVisNode
Monika Klara Rabarison
monika.k.rabarison at ccaix.jsums.edu
Tue May 21 13:14:19 CDT 2002
On Tue, 21 May 2002, Robert Olson wrote:
> Hmm.
> The video capture computer is running, and you see incoming video there?
yes we do
> Do you see the captured video from the video capture box on your display box?
When the problem occurs every stream freezes even our local video.
When it is "waiting for video" we don't get the local video either.
> if you don't see that local video, you might want to check with your local
> networking folks to ensure the traffic is getting from port to port
> properly (or if you have one kicking around, you could plug both machines
> into a fast ethernet hub to test).
I'll check with the network guys though.
> Do you see external video on the video capture machine? If so, you might
> try swapping the network cables on the two machines, see if it acts
> differently then.
Yes we see both external and local video there. I'll try to swap the cable
too. But you know what? Since this morning for the first time somehow the
problem did not occur at all. I have been in the Test Room for hours and
it runs fine. Weird, isn'it?
Monika
> --bob
> At 08:51 AM 5/21/2002 -0500, Monika Klara Rabarison wrote:
> >Hi Bob,
> >The Display machine is a Systemax Mission-10EL Server.
> >Windows 2000 Professional
> >2 Intel Pentium III @1GHz
> >256 MB SDRAM
> >2 18GB SCSI Hard Drives
> >Matrox G200 - only one projector is attached to the Display machine.
> >Intel PRO/100S Desktop Adapter- like for the other AGN computers
> >it is connected to a wall jack linked to a 10BaseT/100BaseTX Cisco
> >switch. I am not sure about the connection before that switch.
> >Thanks,
> >Monika
> >On Mon, 20 May 2002, Robert Olson wrote:
> > > Which OS are you running on this machine? What kind of hardware do you
> > have?
> > > How is it connected to the network?
> > > --bob
> > > At 08:33 AM 5/20/2002 -0500, Monika Klara Rabarison wrote:
> > > >Hello,
> > > >The video drops/freezes very often on our Display
> > > >computer. Sometimes we get "waiting for video" for
> > > >a long period of time before getting back the streams
> > > >on the Display computer although the video computer
> > > >keeps capturing/receiving all the streams.
> > > >Could anyone have an idea about how to fix this?
> > > >Thanks,
> > > >Monika
> > > >Monika Rabarison
> > > >System Administrator
> > > >HPVCI
> > > >Jackson State University
> > > >Lab-(601)979-5933
> > > >RAVE Room-(601)979-1056 or (601)979-1061
