[AG-TECH] Mapping IP addresses to Venues
Jay Beavers
jbeavers at microsoft.com
Thu Mar 21 16:00:37 CST 2002
Can someone explain to me:
* Why are audio and video sent on different IP address / port
pairs for a single Virtual Venue? Why do they not share a single
IP/Port address? Doesn't the payloadtype field in RTP allow you to
effectively discern between audio and video streams?
* How are the IP/port allocated for the Virtual Venues?
For instance, we requested a static allocation of a block of multicast
IP addresses from Internet2. Since multicast traffic is scoped purely
on IP address and since the amount of traffic associated with a Virtual
Venue would generally degrade any other multicast application sharing
the same IP address but using a different port, it seems to me that each
venue should have a dedicated single IP address.
* If you have a dedicated single IP address per venue, is there
anything wrong with following the RTP default ports of 5004 for RTP
traffic and 5005 for RTCP traffic?
Thanks.
- jcb
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20020321/f855ca73/attachment-0001.htm>
